Maya python add audio clip to Time Editor
gabriel.betros4YZVL
gabriel.betros4YZVL
Hi, What is the command to import audio clip into Maya Time Editor? I used the "timeEditorClip" to import animation clips using the "importFbx" parameter to specify the animation path. However I can't find a parameter to specify the audio file path and import it.
I tried the command "TimeEditorCreateAudioClip", but it is opening a browser to choose the audio file and using the command "TimeEditorCreateAudioTracksAtEnd" would create an audio track only. I would appreciate any help.
Thanks.
gabriel.betros4YZVL
ok I completely overlooked the "audio" parameter in the command "timeEditorClip", I just needed to specify the audio path there and it worked.
