Hi, I have a customNode c++ node that outputs a single mesh (MFnMesh.create with MFnMeshData), and it seems to build a correct mesh. But when I plug it into a Bifrost graph, I get a hard crash (see below).
What's odd is if I first generate the mesh, remove history (disconnect it from the custom node), Maya doesn't crash:
[CustoNode.outMesh] --> [Mesh] > OK
[CustoNode.outMesh] --> [Mesh] --> [BifrostGraph] > CRASH
[Mesh] --> [BifrostGraph] > OK
If I replace CustomNode by a makeSphere, or another light custom node, it works properly.
So I've edited CustomNode to output a simple cube (while still retaining its many inputs plugs and heavier computes), and it crashes back...
The top of the crash report seems to indicate there's an issue with getting Set members when the CustomNode is connected:
Crash ID 741299829
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0xFFFFFFFF
Fault address: F0FE60CB in C:\Program Files\Autodesk\Maya2024\bin\DataModel.dll
0001:003550CB Logical offset (see .map file for location)
Call stack:
Module: C:\Program Files\Autodesk\Maya2024\bin\DataModel.dll (-exported-)
Location: DataModel.dllTobjectSet::getFlattenedMemberList + 4B bytes
Decl: public: void __cdecl TobjectSet::getFlattenedMemberList(class TselectionList & __ptr64)const __ptr64
Module: C:\Program Files\Autodesk\Maya2024\bin\OpenMaya.dll (-exported-)
Location: OpenMaya.dllAutodesk::Maya::OpenMaya20240000::MFnSet::getMembers + 59 bytes
Decl: public: class Autodesk::Maya::OpenMaya20240000::MStatus __cdecl Autodesk::Maya::OpenMaya20240000::MFnSet::getMembers(class Autodesk::Maya::OpenMaya20240000::MSelectionList & __ptr64,bool)const __ptr64
Module: C:\Program Files\Autodesk\Bifrost\Maya2024\2.8.0.0\bifrost\bin\BifrostObjectBoardPlugin_2_8_0.dll (-exported-)
Location: BifrostObjectBoardPlugin_2_8_0.dllmayaVectorArrayToObject + 549D8 bytes
Decl: class Amino::Ptr<class Bifrost::Object> __cdecl mayaVectorArrayToObject(class Autodesk::Maya::OpenMaya20240000::MPlug const & __ptr64,class Autodesk::Maya::OpenMaya20240000::MDataHandle & __ptr64)
Location: BifrostObjectBoardPlugin_2_8_0.dllmayaVectorArrayToObject + 2516D bytes
Location: BifrostObjectBoardPlugin_2_8_0.dllmayaVectorArrayToObject + 26F94 bytes
Location: BifrostObjectBoardPlugin_2_8_0.dllmayaVectorArrayToObject + 1447A bytes
Module: C:\Program Files\Autodesk\Bifrost\Maya2024\2.8.0.0\bifrost\bin\BifrostBoardExecutor_2_2_0.dll (-exported-)
Location: BifrostBoardExecutor_2_2_0.dllBifrostBoardJob::Requirements::add + 38D064 bytes
I also compiled on linux to see if anything else popped up, and I didn't see any differences in the call stack, but on rare occasions, I saw a Qt related message:
qobject::connect: cannot queue arguments of type 'tmodelnode' (make sure 'tmodelnode' is registered using qregistermetatype().)
I tried making sure the mesh is properly built, witht UVs, objectGroups, etc. Also tried connecting to the BifrostGraph via cmds.connectAttr or cmds.vnnNode, but still no luck.
Any ideas on what could cause this ? I'm getting desperate here 😅
