Maya Flag error
Maya Flag error
jayantbhatt07
Maya Flag error
jayantbhatt07
 Anyone can help me with this. The command  is giving me an error
Error = ( // Error: line 15: Flags must come before objects: -ed )
textFieldButtonGrp  -buttonLabel "Browse" -tx $cfp -bc rsFileDialog rsTxtFld -ed true filepath;
rajasekaransurjen
textFieldButtonGrp -buttonLabel "Browse" -tx $cfp -bc rsFileDialog -ed true filepath;
jayantbhatt07
//Code by rajasekaransurjen
{ string $sn = `file -q -sn`;
string $cfp = `dirname( $sn )`;
if (`window -exists ScreenCapture`) //closes window if already open
deleteUI ScreenCapture;
window -title "ScreenCapture" ScreenCapture; //creates window
rowColumnLayout -numberOfColumns 4 -columnAttach 1 "left" 0
-columnWidth 1 40 -columnWidth 50 500;
text -label "Path";
button -w 60 -h 28 -label "Capture" -command "Capture";
// show the window we last created
showWindow;
proc rsFileDialog()
string $rsPath[] = `fileDialog2 -ds 1 -fm 3`;
textFieldButtonGrp -e -tx $rsPath[0] rsTxtFld ;
global proc Capture()
string $path = `textField -q -tx filepath`;
string $k = ($path + "/snapshot");
string $ff = ".png";
string $node[] = `ls -sl`;
setAttr "defaultRenderGlobals.imageFormat" 8;
playblast -st 1 -et 1 -v 0 -fmt "image" -qlt 100 -p 100 -w 2000 -h 2000 -f $k;
clear $node;
jayantbhatt07
When I added you line error was ( // Error: line 31: Object 'rsTxtFld' not found. )
tkaap2
Skimming this script, this line that was triggering your original problem:
Should probably be: (rsTxtFld moved to the end)
textFieldButtonGrp -buttonLabel "Browse" -tx $cfp -bc rsFileDialog -ed true filepath rsTxtFld;
The error "Flags must come before objects" means that in the grammar of the command, "verb, adverbs, object", the final object you are operating on has to come last.  In this case, the command `textFieldButtonGrp` is creating the `rsTxtFld` object and assigning it that name.   Everything in the middle is controlled by flags (-stuff -that -follows -dashes) or flag values (-this value -that value -the other value).  The object needs to come last.
Later  in the script, that `rsTxtFld` object is being updated/edited, and if it is not named here, it will not be found.  (That creates the error in Message 4 in this thread).
jayantbhatt07
Hi thank you so much for you help.
saptadwip9
Community Visitor
Community Visitor
how to fix this
