Announcements
Maya fails to load 3d objects and autosave file couldnt retrieve it
Message 1 of 1
My Maya file doesn't load objects which was done the previous day. All the 3D objects and group are not loaded with the warning message " swatches file depend node not found, icon discarded" and some error messages as " // Error: "D:/IQRA/Animation project/Objects_model/scenes/environments_ver_04.ma" line 2060822.8: Syntax error //
// Error: setAttr ".c" -type "float3" 0.0105 0.056699999 0 ; //" . I couldn't find any other things. Am not sure is it because of the size!! . Maya doesnt load layers, textures and shaders too. I even had auto save files in another place which also didn't save properly. But the file size is still showing large as if it has all the contents. Can you please help me in recovering that file. I can also attach error log if you need more info on this issue.
Replies (0)
