maya custom script location for Mac OS users
stevenfila7
stevenfila7
Hello all,
Sorry but I am really confused where to place custom scripts for a Mac OS system in maya.
Do I place the scripts in this folder thread:
Users/Shared/Autodesk/Maya/2011/scripts
or Do I place the script in this one:
Users/Shared/Autodesk/Maya/2011/scripts/prefs/scripts
Please advise and thank you-
Steve
lanh.hong
Hi stevenfila7,
I'm not sure where you would place it for Maya 2011, but for newer versions of Maya, you can place your custom scripts anywhere in your local working directory as long as you have your environment variables set up correctly to point to it.
If you follow this documentation on how to set up your environment, it tells you to to save all scripts into "$HOME/devkit/plug-ins/scripts" and put the environment variable "MAYA_SCRIPT_PATH = $HOME/devkit/plug-ins/scripts" into your Maya.env file.
http://help.autodesk.com/view/MAYAUL/2018/ENU/?guid=__files_Setting_up_your_build_environment_Mac_OS...
Lanh
Lanh Hong
Developer Technical Services
Autodesk Developer Network
I just facing some trouble I'm trying to open script in Maya but is not exist actually anywhere, the script folder is empty I don't know why. if you could help I will be grateful.
