Announcements
Maya crashes after reloading a plug-in
Hi all,
I am developing a plug-in for Maya 2010 using the C++ API. This plug-in declares two commands.
When I unload the plug-in after executing one command, then reload it and execute the command again, Maya crashes without actually entering the command code (MPxCommand::doIt method).
Both commands are registered in function initializePlugin() and deregistered in uninitializePlugin().
I have followed exactly the Maya API documentation, but I don't know what is the reason of the crash.
Any help would be very appreciated.
Thanks in advance.
Javier Taibo.
I have also discovered that when plug-in is unloaded some DLLs used by the plug-in remain locked by Maya.
Is there any additional call to do when unloading the plug-in more than unregistering commands? Is there any problem with linking a MLL plug-in to other DLLs ?
Thanks in advance.
Hi!
I have the same problem. Anybody have an idea why this happens? I am using libraries like CImg and pugixml in my plugin, could this have to do anything with it? I am registering and deregistering all commands used in my plugin and it still crashes Maya when REloaded...
Thanks for your help!
Jan
