Maya camera overscan to scale?
Hi everyone!
I'm currently writing a script which requires me to be able to make the conversions between the different 'Fit Resolution Gate' modes, and have that data in the standard values instead (i.e probably Camera Scale)
The first one I'm trying to calculate is overscan, and then the next will be vertical.
I've been manually plugging in values to try and reverse engineer the forumla, and it's doing my head in. I originally worked out that:
Overscan Scale Value = resX/resY/aspectRatio
When (and only when) the Film Aspect Ratio setting is at 1.5.. however I feel like this is too much of a coincidence to be unrelated. From here I figured I must be missing an unknown variable in the equation, which when the aspect ratio is 1.5, equals 1 if it's a * or / and 0 if it's got something to do with adding and subtracting. From there I've been mucking around with no success..
What I find REALLY confusing is that starting from an aspect ratio of 1 and increasing that number towards 2, the Camera Scale value needed to match the overscan decreases towards a value of 1.. however when you hit around the 2 mark in aspect ratio, the scale value starts increasing again to match the overscan!
If anyone has any information on this (or converting vertical etc) that would be amazing!
Cheers,
Kaine
Edit:
I figure it is also potentially reliant on the focal length as well.
