Maya 2020 MayaPy version is showing 3.8, expecting 2.7
mostly_human
mostly_human
Just starting to learn Python and the learning resources I am using are all 2.7 but the mayapy.exe included with Maya 2020 is showing v3.8. I thought the vfx standard was still at 2.7 so I am a bit confused and having code incompatibility issues using this mayapy.exe with an external ide. If I check the python version in the maya script editor it does say 2.7.
Specifically I am using PyCharm using mayapy.exe 3.8 as the interpreter, I also added the context files from the devkit.  If I type
print "hello"
 It will underline it in red to show an error, but if I use python 3 syntax
print("hello")
It wont underline it in red.
And of course the Python 2 syntax does work correctly in Maya just not sure why the ide is doing what it's doing.
mostly_human
Okay, so I saw that the vfx reference is requiring Python 3 starting in 2020 which explains why the mayapy version has been updated, but why is the script editor still showing version 2.7?  How do I get Maya to use python 3?
mostly_human
also, apologies, I did not mean to press the "need an answer" button, I meant to press reply, i was moving fast and they are the same color.  Then I pressed it again thinking it might remove the "need an answer" status but it just seemed to escalate it further.
cheng_xi_li
Autodesk Support
Autodesk Support
It should be 2.7. Do you have Python 3 installed on your computer? It could affect Maya's Python environment.
Maya 2020(released in CY2019) can't use Python 3. The next release(released in CY2020 or later) after Maya 2020 will use Python 3.
Yours,
Li
mostly_human
I only have 2.7 installed.  I am completely stumped.  So the mayapy version in the 2020 bin directory definitely should not be showing up as 3.8 like it is?
cheng_xi_li
Autodesk Support
Autodesk Support
No, it shouldn't.
Could you check your system environment? There are some other software could have installed or setup a Python 3 environment.
Yours,
Li
Yours,
Li
I'm having the same issue. And it has not been resolved. It seems to come from PyCharm. There's a discussion about it here:
https://youtrack.jetbrains.com/issue/PY-39469
