Maya 2017: QMake does not create correct makefile / makefile does not compile
Message 1 of 1
I've been following the standard tutorial for building QT plugins and I can't pass step 7 of "building the plugin."
When I run qmake, instead of creating 'helixQtCmd.mak' I get 'Makefile', 'Makefile.debug' and 'Makefile.release'
If I try to run nmake on this makefile from a normal command prompt (Windows 10) nmake is not specified, but on both VS2013 and VS2015 developer prompts I get an error code 0x0...135 which I think means it doesn't find the compiler.
So my questions are:
1. is it fine that the makefile is different?
2. what is the compiler I need and how do I get it?
thanks!
Replies (0)
