Maya 2017 not running - error pop up message
Maya 2017 (Windows 10 Pro) not opening/running.
First time seeing error message, been working normally before.
Attached screenshot of pop up message stating "File either not designed to run on windows or contains error".
mspeer
Hi!
You may join the following thread (looks like you both have the same issue):
https://forums.autodesk.com/t5/maya-forum/maya-2017-not-opening/td-p/7314029
Please post your Hardware Specs there.
