Announcements
Maya 2017 missing MCallbackId header
I can not seem to find the MCallbackId header in the Maya 2017 includes.
Also in the C++ documentation MCallbackId is completely missing and in the Python docs it is just a blank page.
https://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=__py_ref_class_open_maya_1_1_m_callback_id_html
Is there something I'm missing? It seems that in Maya 2016 it was still included. I also checked in Maya 2018 and it is also missing from there.
Cheers
Marcell
cheng_xi_li
Autodesk Support
Autodesk Support
I think it is fine.
If you open MMessage.h, you'll find
typedef MUintPtrSz MCallbackId;
I think you the reason you could find python one is Maya documents are generated based on the comments with cpp files. Python 2.0 APIs are wrappers, so there is a header file for MCallbackId without implementation. But for C++, it is just a uint_ptr typedef.
Yours,
Li
Yes you are right!
Thank you very much
Cheers
Marcell
