Maya 2016 (OS X) hangs on using PySide or PyQt
Hey everyone.
I'm trying some basic stuff with PySide. But when where I import anything other than the library, OS X's wheel of death appears and Maya stops responding.
This is with PySide and PyQt.
Example code:
import PySide.QtCore as qc
import PySide.QtGui as qg
class simpleUI(qg.QDialog):
    def __init__(self):
        qg.QDialog.__init__(self)
        self.setWindowTitle('Simple UI')
        self.setWindowFlags(qc.Qt.WindowStaysOnTopHint)
        self.setModal(False)
        self.setFixedHeight(250)
        self.setFixedWidth(300)
dialog = simpleUI()
dialog.show()
I've installed them both on my system via Brew. Do I need to do anything more to make Maya and PySide/Qt talk nicely? PySide/Qt both work well outside of maya, so I can only think it's a configuration issue.
The error report when I forced quit Maya:
https://paste.ee/p/q4mvk#
vijaya.prakash
I think you are using the default PyQt that comes with OS X. But Maya uses the customized PyQt. You have to download the PyQt sources and build it against Maya. Then use those libraries.
Please check the following link for more information.
http://around-the-corner.typepad.com/adn/2015/05/building-sip-and-pyqt-for-maya-2016.html
Vijaya Prakash.
