Maya 2015 Plugin Wizard and Visual Studio 2013?
jazioblaq
jazioblaq
Hello, I am running Maya 2015 on Windows 8.1
I'd like to start learning to program Maya plugins using Visual Studio (which I'm running VS 2013). I followed these instructions for installing the Maya Plugin Wizard:
Follow these steps to install the wizard
  1. The wizard can be found in devkit\pluginwizard\MayaPluginWizard2.0.zip under Maya's install folder. Unzip this file into a local folder.
  2. Copy the following files to the C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\vcprojects folder:
    MayaPluginWizard.vsdir
    MayaPluginWizard.vsz
    MayaPluginWizard.ico
  3. Notice that the unzipped file contains a top-level folder named MayaPluginWizard and within that a sub-folder which is also named MayaPluginWizard. Copy the top-level MayaPluginWizard folder to C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\VCWizards
Note* instead of the  C:....\Microsoft Visual Studio 11.0\...,  I placed in C:....\Microsoft Visual Studio 12.0\....
At point of New -> Project I see the MayaPluginWizard icon. When I click to proceed to create the new project, I get "...project creation failed"
I searched several hours for a solution and I am not sure what it is. I am wondering if Maya Plugin Wizard does not work with my version of Visual Studio, or what I could be doing wrong. Thank you. Im a newbee to programming and would really like to learn!!
borbs727
I'm getting the same error with the same setup.
borbs727
Found the answer!
Go into the MayaPluginWizard.vsz file (I just used Notepad++) and change version number in this line...
Wizard=VsWizard.VsWizardEngine.11.0
... to what ever version of Visual Studio you're using, I'm using 12.0.
Wizard=VsWizard.VsWizardEngine.12.0
Hope this helps.
I am running Maya 2016 and VS 2013. I did what you recommended which helped me get past the project creation part but I get a bunch of Script errors when the Plugin Wizard UI launches. Any ideas about this?
