Maya 2014 deformer attributeAffects
Hello!
I am having a strange issue with Maya 2014 and a custom deformer I have written that was working up until at least version 2011 (the version I last compiled it for).  It appears like attributeAffects isn't working correctly.  I have setup a few attributes that I want to affect outputGeom but the deform method is not being called when an input attribute changes.
My inputs are of types color, boolean, matrix and a generic attribute that accepts kMesh, kNurbsSurface or kNurbsCurve.  Changing any of these values will not cause the deform method to run.  If I change the envelope attribute, the deform method is run correctly.  This was definitely working in Maya 2011 back when I compiled it last.  I am not recieving any compilation errors so it appears as if everything is setup correctly.
Has anything changed since Maya 2011 that could cause this?  I am using Visual Studio 2010, would that version cause an issue?
Any help would be much appreciated!
-tony
It seems that I had to just shift around where I was calling addAttribute and attributeAffects.  Sorry for the noise!
