mata api c++ writeToFile not working for float
ryan.lewis8N66A
Observer Observer
ryan.lewis8N66A
Observer
Observer
trying to write out data to a texture ( exr would be awsome).
the code snippit should work form the examples in the api .
it does not and i get no errors.
if i change the type to char its fine. why wont it work for float.?
is there another /better way to do this?
better solution to write out exr textures?
MImage animationImage;
int fWidth = 800;
int fHeight = 800;
int fChannels = 4;
animationImage.create( fWidth, fHeight, fChannels, MImage::kFloat);
float *dest = animationImage.floatPixels();
for (int y=0; y < fHeight; y++)
    for (int x=0; x < fWidth; x++)
      *dest++ = 0.5;
      *dest++ = 0.5;
      *dest++ = 0.5;
      if (fChannels ==4)
        *dest++ = 0.0;
animationImage.writeToFile ("D:/myTestiff.iff", "iff") ;
cheng_xi_li
Autodesk Support
Autodesk Support
Hi Ryan,
MImage is a little bit outdated now, if you want to write exr float images, you can use MTextureManager.
Here is an updated version of your code:
const int fWidth = 800;
	const int fHeight = 800;
	const int fChannels = 4;
	float *floatPixels = new float[fWidth*fHeight*fChannels];
	float *dest = floatPixels;
			*dest++ = 0.5f;
			*dest++ = 0.5f;
			*dest++ = 0.5f;
			if (fChannels ==4)
				*dest++ = 1.0f;
	auto render = MHWRender::MRenderer::theRenderer();
	auto textureManager = render->getTextureManager();
	MHWRender::MTextureDescription texDesc;
	texDesc.setToDefault2DTexture();
	texDesc.fWidth = fWidth;
	texDesc.fHeight = fHeight;
	texDesc.fDepth = 1;
	texDesc.fTextureType = MHWRender::MTextureType::kImage2D;
	texDesc.fFormat = MHWRender::MRasterFormat::kR32G32B32A32_FLOAT;
	texDesc.fBytesPerRow = fWidth * fChannels * sizeof(float);
	texDesc.fBytesPerSlice = fWidth * fHeight * fChannels * sizeof(float);
	texDesc.fArraySlices = 1;
	texDesc.fEnvMapType = MHWRender::MEnvironmentMapType::kEnvNone;
	auto myTex = textureManager->acquireTexture("myexrfile",texDesc,floatPixels,false);
	textureManager->saveTexture(myTex,"D:/test.exr");
	textureManager->releaseTexture(myTex);
	delete floatPixels;
	floatPixels = NULL;
	dest = NULL;
	return MS::kSuccess;
Yours,
Li
ryan.lewis8N66A
Observer
Observer
that's great. thanks!
did not even see that in the sdk.
i tried the code. the exr opens in maya but not photoshop ( or unreal4).
i tried a couple different  MrasterFormats,- kR16G16B16A16_SNORM no luck.
any thoughts about why that happens?
something else in the headers or compression?
i am using maya2014 and vs2012.
ryan
ryan.lewis8N66A
Observer
Observer
looking at again..
 if i save out and exr or tga as kR32G32B32A32_FLOAT
then read them back in to maya (in fcheck) -still can not open in photoshop.
as an exr the rg channels are black. ie only have blue
as a tga the gb channels are black. ie only have red
so even as an image it seems the data is wrong.
what am i missing?
ryan
