Make some sound when render is finished.
sw.atd
Observer Observer
sw.atd
Observer
Observer
Can you make alarm when render is finished or send massage to mobile phone.
thx
olarn
Have you tried "post render MEL" in the render settings?
Apparently there's a command for it too.
https://help.autodesk.com/view/MAYAUL/2019/ENU/?guid=__Commands_prepareRender_html
jordan.giboney
Autodesk Support
Autodesk Support
Hi @sw.atd
Thanks for posting! Did you have a chance to review @olarn suggestion? Any success with that?
Also, I would recommend posting this to our Maya Idea Station - here, other Maya users can vote for this feature to be implemented into a future version of Maya 🙂
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Autodesk Support
Autodesk Support
Hi @sw.atd
I hope you are doing well! I wanted to check in and see how things were going. Did @olarn's suggestion work for you? If so, please mark the solution in this thread so others can find the answer faster 🙂
Jordan Giboney
mspeer
Hi!
I will mark the answer from @olarn as solution.
By using the Post render MEL you can execute almost everything you can think of, even system commands,
so there should no problem to trigger any action you want to happen.
I have a solution to this. Visit my website: https://www.jordsoundservices.com/
Its a ZIP file that helps you get a post rendering sound..
sflipse
this guy has a solution but it has to be retyped each time in the MEL but it works great 🙂 https://www.jordsoundservices.com/
