Loop over selected objects and print their polygon (triangle) count
I'm writing a script that with a selected number of objects, writes out the name of each selected object along with it's individual poly count. So far so good. Only I can't figure out how to do that on an object by object basis. The poly count is added in total and not done individually.
Here's what I have
import maya.cmds as cmds
import sys
# List all selected objects
selectAll = cmds.ls( selection = True )
if len(selectAll) < 1:
    print "No selection"
else:
    for obj in selectAll:
    print obj
    # query the number of faces
    faces = cmds.polyEvaluate( f = True )
    # query the number of triangles
    triangles = cmds.polyEvaluate( t = True )
    print "Selected triangles: " + str(triangles)
    results = "Selected triangles: " + str(total_faces)
    sys.stdout.write(results)
haggi_master
Your code is a bit confusing, maybe it is only a copy/paste problem but after the "for obj in..." should be a indentation:
import sys
else:
        print obj
RFlannery1
For many Maya commands, if you don't specify any object(s), then the command will run on whatever is selected.  This is what is happening in your case.  (In general it is better to include the object(s) in the call to the Maya command.  Sometimes something else in the script can change the selection, and the command won't give the results you expect.  But if the objects are explicitly named in the command, then it will return the correct result no matter what is selected.)
So, for this specific case, the problem can be fixed by doing something like this:
    faces = cmds.polyEvaluate(obj, f=True)
