Load Render Setup JSON file with python
Hello all,
Is there a python method to load my exported (JSON file) Renderlayer setup with python?
All I can see with "echo all commands" on are the UI commands, which are not useful.
I have to say that the Documentation for the new Render Setup system is realy minimal.
Thanks in advance!
Cheers,
David
cheng_xi_li
Autodesk Support
Autodesk Support
I am looking into this now. I'll need to talk with our engineers about this. It might be a little bit delay because of holiday. Sorry for the inconvenience.
Yours,
Li
Hi Li,
Thanks you for your response.
Waiting for your feedback!
Cheers,
David
cheng_xi_li
Autodesk Support
Autodesk Support
Sorry for keeping you waiting. I've got a solution for you now.
import maya.app.renderSetup.model.renderSetup as renderSetup
import json
"""import is decode(jsonObject, importOption, optionalPrefix)
jsonObject is the json string you'll need to import.
importOption could be DECODE_AND_RENAME, DECODE_AND_MERGE, DECODE_AND_OVERWRITE
The optionalPrefix could be none if you don't want a prefix and it is only working with DECODE_AND_RENAME option
def importRenderSetup(filename):
    with open(filename, "r") as file:
        renderSetup.instance().decode(json.load(file), renderSetup.DECODE_AND_OVERWRITE, None)
Hope it helps.
Yours,
Li
stormpostproduction
Hi Li,
Thank you very much!
This is exactly what I was looking for!
Cheers,
David
deven.saxenaP7BD5
Is there a way to rename the render layer upon import?
What I am trying to do is to export a template_wall render layer and import it via Json and rename it to "wall_01".
pablo.valladares.r
im try to import a json file like the script to add a render layer but I don't have idea to insert the string of the name of the file "script.json" from the RSTemplates folder
could somebody helpmeet, thank you.
