Importing Alembic through File > Import does not automatically reconnect Face Sets, Importing through Cache > Alembic Cache > Import Alembic does
sophia.berger966CF
sophia.berger966CF
Hi! Noticing some weird behavior, not quite sure why it would be happening but my test case sphere that has face sets on it does not reconnect when brought in through File > Import but DOES through Cache > Alembic Cache > Import Alembic. These are the settings for both:
Is this a settings issue or is there something else happening? I can show the command line output if necessary
Kahylan
Hi!
Alembic is a 3rd Party Format provided by Imageworks and Lucas Film.
With 3rd party formats like this, using the custom export/import process will normally give you better results.
Is there a reason why you need to use the File->Import method?
sophia.berger966CF
Not really, more just something I noticed (in the event that someone goes outside the workflow it may be an issue but by default shouldn't be.) Thanks for the information!
