Import character as refrence
jayantbhatt07
jayantbhatt07
Hi guys this is my command to import the charater but I want this character as a reference rather than import. Any idea?
Refrence cmd -
  1. file -reference "C:/mystuff/wilma.mb";
global proc UE4_Man_Scale()
string $file_Path = (`internalVar -userPrefDir`) + "icons/3D_Ghost_Script/Unreal_Character_Scale.ma";
file -import $file_Path;
rajasekaransurjen
Try this...
    file -r -type "mayaAscii"  -ignoreVersion $file_Path;
jayantbhatt07
Yes this working thank you so much. I have one doubt I assigned this procedure to the button (as a command) but  when I click on the ( button1 ) it is refrencing that character. Is that possible when I again hit that button it should remove the refrenced character using any alternate key (like holding alt + Button1) or (ctrl + button1).
To remove the refrence - - -  The command is ( -removeReference(-rr) )
SEE THE COMMAND _ _ _ _
// create a window
window;
// define the layout of controls added
// to the window.
columnLayout;
// create a couple of buttons
button -label "button1" -c "UE4_Man_Scale()";
// show the window we last created
showWindow;;
// It will import your character as a refrence
UE4_Man_Scale();
rajasekaransurjen
Try this....
    string $rsRefQry[] = `file -q -r`;
    string $rsRefFile[];
    int $rsCont;
    for($i=0;$i<size($rsRefQry);$i++)
        $rsRefFile[$i] = `referenceQuery -f -shn $rsRefQry[$i]`;
    for($j=0;$j<size($rsRefQry);$j++)
        if($rsRefFile[$j]=="Unreal_Character_Scale.ma")
            $rsCont += 1;
    if($rsCont==0)
    else
        file -rr $file_Path;
jayantbhatt07
And on more thing If I press any button in the keyboard and left mouse button it is removing the reference which I don't want. ex ( F + LMB ) removing the reference.
jayantbhatt07
Finally Figured it out thank you so much man here is the final command
// final
// create a window
window -title "Nut" -menuBar true -w 220 -h 200 "";
// to the window.
columnLayout;
// create a collapsible frame layout
frameLayout -collapsable true -label "Nuts";
// add the other controls
flowLayout -columnSpacing 1 -w 220 -h 30;
// create six symbol buttons with related mel command
symbolButton -image "commandButton.png" -command "Character()";
setParent ..;
showWindow;
global proc Character()
int $mods = `getModifiers`;
print ("Modifiers are:");
int $getModifierPressed = `getModifiers`;
if ( $getModifierPressed == 0)
//If I PRESSED SHIFT IT WILL IMPORT CHARACTER
if (($mods / 1) % 2)
//If I PRESSED CTRL IT WILL IMPORT CHARACTER
if (($mods / 4) % 2)
file -ir $file_Path;
// if you want to use alt then here is the command I'm writing this so it would  be benefit for other users
if (($mods / 😎 % 2) print (" Alt");
