If nothing selected
If nothing selected
If nothing selected
I'm writing a python script and I want to check if there's nothing selected. Si I got this:
        if target == None:
            cmds.error("Please select an object")
But it doesn't work. Even if nothing is selected, the script continues beyond my if statement. Any idea?
mspeer
Hi!
It seems you accidentally did not add the complete script.
No one can say why
if target == None:
is not True for a scene without any selection, without any further data.
If the statement is True then it will stop after the error message (tested in  Maya 2019.1)
Here is the entire script.
# Fires a curve from the camera to the selected object. By Robert Rioux. Inspired by NavKit by Laurent Taillefer. :-)
import maya.cmds as cmds
target = cmds.ls(sl=True)
class rayProject(object):
   def __init__(self,*args):
       self.rayProjectWin = 'rayProject'
       if cmds.window(self.rayProjectWin, exists=True):
           cmds.deleteUI(self.rayProjectWin)
       self.buildWin()
   def buildWin(self,*args):
       self.rayProject = cmds.window(self.rayProjectWin, t="Ray Project", tlb = True, w=100, h=30, bgc= [0.4,0.4,0.4])
       theRowLayout = cmds.rowColumnLayout(nc=1,columnWidth=(30,1), h=30)
       cmds.button(label="Fire!",  width = 80, command = self.fire)
       cmds.setParent( theRowLayout )
       # Display the window
       cmds.showWindow(self.rayProjectWin)
# Project the curve
   def fire(*args):
       print target
       if target == None:
           #cmds.error("Please select a locator")
           print target
           print "Check if statment"
       else:
           print "else"
           transform = maya.cmds.xform( target, q=True, ws=True, t=True )
           pan = cmds.getPanel(wf=True)
           cam = cmds.modelPanel(pan, q=True, camera=True)
           transformCam = maya.cmds.xform( cam, q=True, ws=True, t=True )
           cmds.curve (p=[(transformCam[0],transformCam[1],transformCam[2]),(transform[0],transform[1],transform[2])], d=1)
           newCurve =  cmds.ls(sl=True)
           cmds.xform (r=True, piv=(transformCam[0],transformCam[1],transformCam[2]))
           cmds.xform (s=(10,10,10))
           cmds.select (target)
rayProject()
mspeer
Hi!
This is what i missed:
Please use this for the if statement:
if not target:
Great! Thank you. I will give it a try tomorrow.
