I can't open plugin manager!!! Please help me :'(
Basically my arnold was not working properly, and then it disappeared from my tool bar. I went to open plugin manager, then I realized PM cannot even be opened... tried to reboot and re-install.. nothing happened. (No error message, just simply cannot be opened)
morten_bohne
Could be it just shows the plugin-manager outside your screen area? This often happens with ui-elements if you unplugged a monitor or switched main-monitor
Try resetting the position of the window with something like this (mel):
windowPref -topLeftCorner 0 0 -widthHeight 450 411 -maximized false -parentMain true pluginManagerWindow;
...it can also be edited from the windowPrefs.mel-file in your prefs folder
hope it helps 🙂
