How to use Python gradientControlNoAttr
1140534355
Message 1 of 33
1140534355
Hello, everyone, I'm new to Python. I found gradientControlNoAttr layout in Python document today, but I don't know how to define this. I've been using def source_v(source_cv) function before, and I want to know how I can change it to gradientControlNoAttr, or if there is a case for reference.
def source_v(source_cv):
    attraction_profile = cmds.getAttr(source_cv + ".attractionProfile[*]")
    for cv in cmds.ls(sl=True, dag=True, typ="nurbsCurve"):
        point_num = len(cmds.getAttr(cv + ".attractionProfile[*]")) or 0
        for i in range(point_num)[len(attraction_profile):]:
            cmds.removeMultiInstance("{}.attractionProfile[{}]".format(cv, i), b=True)
        for i, (pos, value, interp) in enumerate(attraction_profile):
            cmds.setAttr("{}.attractionProfile[{}].attractionProfile_Position".format(cv, i), pos)
            cmds.setAttr("{}.attractionProfile[{}].attractionProfile_FloatValue".format(cv, i), value)
            cmds.setAttr("{}.attractionProfile[{}].attractionProfile_Interp".format(cv, i), interp)
source_cv = cmds.ls(sl=True, dag=True, typ="nurbsCurve")[0]
cmds.gradientControlNoAttr('attractionProfile', h=120)
cmds.gradientControlNoAttr('attractionProfile', ck=0,e=1)
cmds.rowLayout(nc=3)
cmds.floatFieldGrp('posFieldRadius', pre=3, l="Selected Position", nf=1, v1=0.000, s=1.0, cw=(1, 70))
cmds.floatFieldGrp('valFieldRadius', pre=3, l="Selected Value", nf=1, v1=1.000, s=1.0, cw=(1, 70))
cmds.optionMenuGrp('interpMenuRadius', cw=(1, 50), l="Interpolation")
cmds.menuItem(l="  None  ")
cmds.menuItem(l="  Linear  ")
cmds.menuItem(l="  Smooth  ")
cmds.menuItem(l="  Spline  ")
cmds.setParent( '..' )
Accepted solutions (4)
Replies (32)
Message 21 of 33
1140534355
import maya.cmds as cmds
import maya.mel as mel
def getTheNurbsCurve():
    source_curve = cmds.ls(sl=True, dag=True)
    if not source_curve:
        cmds.warning('No curve was selected')
        return
    else:
        source_curve = source_curve[0]
    # Check if the curve has "attractionProfile"
    if not cmds.objExists(source_curve + '.attractionProfile'):
        cmds.warning('{} is missing "attractionProfile"'.format(source_curve))
        source_curve = None
    return source_curve
def currentKeyChanged(currentData):
    currentIndex = cmds.gradientControlNoAttr('attractionProfile', q = True, currentKey = True)
    if currentIndex == -1:
        return
    # Get the values for that key
    currentData = cmds.gradientControlNoAttr('attractionProfile', q = True, asString = True)
    if not currentData:
        return
    a = currentData.split(',')
    posVal = float(a[currentIndex*3])
    valVal = float(a[currentIndex*3+1])
    interp = int(a[currentIndex*3+2])
    # Update the two floatFields
    cmds.floatFieldGrp('posFieldRadius', e = True, v =[posVal]*4)
    cmds.floatFieldGrp('valFieldRadius', e = True, v =[valVal]*4)
    interp=cmds.optionMenu(interp, query=True, value=[interp]*4)
def posModified(val):
    # Change the position of the selected key
        return
    a[currentIndex*3+1] = str(val)
    newData = ','.join(a)
    currentData = cmds.gradientControlNoAttr('attractionProfile', e = True, asString = newData)
def valModified(val):
        return
    a[currentIndex*3] = str(val)
def interpModified(val):
        return
    a[currentIndex*3+2] = str(val)
def setUpRamp():
    # This function will make the ramp in the UI match the existing values of the ramp curve
    attributeData = []
    for i in cmds.getAttr(source_curve + ".attractionProfile", mi = True) or []:
        attributeData.append(cmds.getAttr("{}.attractionProfile[{}].attractionProfile_Position".format(source_curve, i)))
        attributeData.append(cmds.getAttr("{}.attractionProfile[{}].attractionProfile_FloatValue".format(source_curve, i)))
        attributeData.append(cmds.getAttr("{}.attractionProfile[{}].attractionProfile_Interp".format(source_curve, i)))
    # Set the data
    currentData = cmds.gradientControlNoAttr('attractionProfile', e = True, asString = str(attributeData))
def rampModified(gradient_data):
    # Convert the gradient_data from a unicode (string) to a list
    gradient_data = gradient_data.split(',')# Split the string up
    # We will convert each element from a string to a float or int
    data_list = []
    for i,s in enumerate(gradient_data):
        # If the elements index is a multiple of 3
        # we want it to be an int
        # since every third element represents the interpolation
        # we check for this by using modular arithmetic (the % sysmbol)
        if (i+1)%3 == 0:
            data_list.append(float(s))
        else:
    # Then we will split up the data into chunks of 3
    # so instead of having 1 list of data, we have a list of lists
    # where each element contains all the data for a specific cv
    print (type(len(data_list)/3))
    attraction_profile = []
    for i in range(int(len(data_list)/3)):
        attraction_profile.append(data_list[i*3:(i*3)+3])
    source_curve=getTheNurbsCurve()
    # Do whatever it is you were doing with that data
    # THIS WILL AFFECT ALL THE CURVES NOT JUST THE ONE YOU
    # SELECTED WHEN YOU LAUNCHED THE WINDOW
    for eachCurve in (cmds.ls(sl=True, dag=True) or []) + [source_curve]:
        for i in cmds.getAttr(eachCurve + ".attractionProfile", mi = True) or []:
            cmds.removeMultiInstance("{}.attractionProfile[{}]".format(eachCurve, i), b=True)
            cmds.setAttr("{}.attractionProfile[{}].attractionProfile_Position".format(eachCurve, i), value)
            cmds.setAttr("{}.attractionProfile[{}].attractionProfile_FloatValue".format(eachCurve, i), pos)
            cmds.setAttr("{}.attractionProfile[{}].attractionProfile_Interp".format(eachCurve, i), interp)
def clear():
    # To do the clear we need to edit the attribute not the ui
    # since gradientControl keys can't be edited via command
    for eachCurve in (cmds.ls(sl=True, dag=True, typ="nurbsCurve") or []) + [source_curve]:
        # Remove all the data
        # Add the two standard keys back in with linear interpolation
        attraction_profiled = [[0,1,1],[1,1,1]]
def set__key():
    source_curve = getTheNurbsCurve()
    for i in cmds.getAttr(source_curve + '.attractionProfile', mi = True):
        cmds.setKeyframe(source_curve + '.attractionProfile[{}].attractionProfile_Position'.format(i))
        cmds.setKeyframe(source_curve + '.attractionProfile[{}].attractionProfile_FloatValue'.format(i))
        cmds.setKeyframe(source_curve + '.attractionProfile[{}].attractionProfile_Interp'.format(i))
if cmds.window("mayaTool", exists=True):
    cmds.deleteUI("mayaTool")
cmds.window("mayaTool", t="mayaTool",
          w=460, h=500, sizeable=True, mnb=True, mxb=False ,menuBar=True)
cmds.scrollLayout('scrollLayout')
cmds.gradientControlNoAttr('attractionProfile', w=460, h = 120,ck=0,changeCommand = rampModified,)
cmds.rowLayout(nc=2)
cmds.button("reset", w=230, h=30, c="clear()", bgc=(0.4, 0.2, 0.3))
cmds.button("Set key", w=230, h=30, c="set__key()", bgc=(1, 0.05, 0))
cmds.separator(h=5)
# Add the other widgets
cmds.floatFieldGrp('posFieldRadius', pre=3, l="Selected Position", nf=1, v1=0.000, s=1.0, cw=(1, 70), changeCommand = posModified)
cmds.floatFieldGrp('valFieldRadius', pre=3, l="Selected Value", nf=1, v1=1.000, s=1.0, cw=(1, 70), changeCommand = valModified)
cmds.gradientControlNoAttr('attractionProfile', e = True,currentKeyChanged = currentKeyChanged,)
interp=cmds.optionMenuGrp( cw=(1, 70), l="Interpolation",changeCommand = interpModified)
cmds.showWindow("mayaTool")
Message 22 of 33
jmreinhart
        return
    else:
        source_curve = None
    return source_curve
        return
    if not currentData:
        return
    interpStrings = ['  None  ','  Linear  ','  Smooth  ','  Spline  ']
    print  interpStrings[interp]
    cmds.optionMenuGrp('interpolationMenu', e=True, value = interpStrings[interp])
        return
        return
        return
    val = interpStrings.index(val)
def setUpRamp():
    attributeData = []
    # Set the data
    data_list = []
        if (i+1)%3 == 0:
        else:
def clear():
def set__key():
cmds.separator(h=5)
cmds.gradientControlNoAttr('attractionProfile', e = True,currentKeyChanged = currentKeyChanged)
cmds.optionMenuGrp('interpolationMenu', cw=(1, 70), l="Interpolation",changeCommand = interpModified)
setUpRamp()
The interp works now, and I fixed the issue where you were no longer loading the existing ramp from the selected curve.
Message 23 of 33
1140534355
Thank you, you're amazing. Can you get rid of that error? I tried many times, but I couldn't get rid of it.
Error: line 1: No object name specified. #
# Error: line 1: No object name specified. #
# Error: line 1: No object matches name: AttributeEditor|MainAttributeEditorLayout|formLayout98|AEmenuBarLayout|AErootLayout|AEStackLayout|AErootLayoutPane|AEbaseFormLayout|AEcontrolFormLayout|AttrEdnurbsCurveFormLayout|scrollLayout24|columnLayout361|frameLayout161|columnLayout771|columnLayout772|attractionProfileRampForm|attractionProfileSi
Message 24 of 33
jmreinhart
Did you run the code I sent, or copy a chunk of it over to yours?
Message 25 of 33
1140534355
Yes I reported an error when I modified the parameters, but it did not affect the use. By the way, actually, I don't want to open the UI directly to get parameters. I think there will be a default parameter for opening UI directly, such as Attraction _ Profiled = [[0,1,3], [1,1,3]]. I wanted it to be an executable function, but it doesn't seem to be executed now.
Message 26 of 33
jmreinhart
I do not get an error when I run my the code. And I can use all of the UI functions without error, except for reset.
What are you doing that is producing an error?
Message 27 of 33
1140534355
It will appear when I adjust the ramp curve, but it doesn't affect it. I'll change this slowly. Now I don't want to get parameters through (setUpRamp ()). I want to give UI a fixed parameter. What should I do to use it (attraction_profiled)
Message 28 of 33
jmreinhart
Use the code that is in setupRamp.
But Delete the getAttr, and put whatever data you want to have by default instead.
Message 29 of 33
jmreinhart
If your issue was solved please mark this post as solved.
Message 30 of 33
1140534355
Hello, now everything is fine in the code, but why after I reset it, the curve of UI interface will not become [[0,1,3],[1,1,3]], but [[0,1,3],[1,0,3]], even if I modify the parameters,
Message 31 of 33
jmreinhart
Could you post the code for your reset function?
Message 32 of 33
1140534355
Hello, the current code is normal, but it needs to be changed to' 1,0,3,1,1,3'. It should be that pos and value are reversed, but I can't solve this problem after changing pos and value.
        return
    else:
        source_curve = None
    return source_curve
        return
    if not currentData:
        return
    print  (interpStrings[interp])
        return
        return
        return
def setUpRamp():
    attributeData = []
    # Set the data
    data_list = []
        if (i+1)%3 == 0:
        else:
def clear():
    # To do the clear we need to edit the attribute not the ui # since gradientControl keys can't be edited via command
            attraction_profile = [[0,1,3],[1,1,3]]
                cmds.setAttr("{}.attractionProfile[{}].attractionProfile_Position".format(eachCurve, i), pos)
                cmds.setAttr("{}.attractionProfile[{}].attractionProfile_FloatValue".format(eachCurve, i), value)
            # Reset the ramp in the UI
                currentData = cmds.gradientControlNoAttr('attractionProfile', e = True, asString = '1,0,3,1,1,3')
#wingdow
cmds.gradientControlNoAttr('attractionProfile', w=460, h = 120,ck=0,changeCommand = rampModified,currentKeyChanged = currentKeyChanged)
cmds.rowLayout(nc=8)
cmds.button("rest", w=90, c="clear()")
#setUpRamp()
cmds.text("Position:")
cmds.floatFieldGrp('valFieldRadius', pre=3, nf=1, v1=1.000, s=1.0, cw=(1, 50), changeCommand = valModified)
cmds.text("Value:")
cmds.floatFieldGrp('posFieldRadius', pre=3,nf=1, v1=0.000, s=1.0, cw=(1, 50), changeCommand = posModified)
cmds.text("Interpolation:")
cmds.optionMenuGrp('interpolationMenu', cw=(1, 20),changeCommand = interpModified)
setUpRamp()
Message 33 of 33
jmreinhart
I reordered those bits of code so that the order is floatValue, Position, Interp Value for everything and now it behaves the way you want.
        return
    else:
        source_curve = None
    return source_curve
        return
    if not currentData:
        return
        return
        return
        return
def setUpRamp():
    attributeData = []
    # Set the data
    data_list = []
        if (i+1)%3 == 0:
        else:
        for i, (value, pos, interp) in enumerate(attraction_profile):
def clear():
            attraction_profile = [[1,0,3],[1,1,3]]
#wingdow
cmds.button("reset", w=90, c="clear()")
#setUpRamp()
cmds.text("Value:")
setUpRamp()
