How to use passThroughToOne / passThroughToMany in an own node?
Can I access the passThroughToOne/Many functions of other nodes from c++ code? I try to find the correct object in the dependency graph and need to know whichoutput mesh belongs to which input mesh on a node. The node reconnects the meshes with passThrough functions when it is deleted, but I do not see how to access this functions in my code.
cheng_xi_li
Autodesk Support
Autodesk Support
I am afraid you can't call it and there isn't an equivalent API or MEL for it.
Yours,
Li
