How to sort a string array by numeric value?
malcolm_341
Message 1 of 14
malcolm_341
Is it possible to sort a string array numerically?
I have this
string $array[] = {"3", "1", "9" "22", "2"};
and I want this
{"1", "2", "3" "9", "22"};
Replies (13)
Message 2 of 14
mcw0
Convert your numerical string array to an integer array.  Then sort.  Now loop through the sorted values and convert back to string to get the indices to sort your original numerical string array.
Message 3 of 14
malcolm_341
That won't work unfortunately, part of the string array is names so if I convert to int the names are lost. I'd like to sort this list
{"8=geo32", "6=geo26", "3=geo87", "22=geo11", "1=geo3", "2=geo7"}
and get this
{"1=geo3", "2=geo7", "3=geo87", "6=geo26", "8=geo32", "22=geo11"}
Message 4 of 14
mcw0
Tokenize with the "=", then you have only numbers as the first token
Message 5 of 14
malcolm_341
Yep, exactly, I tried that for 3 days, but couldn't figure out how to then stitch the sorted number list back onto the object names in the right order.
Message 6 of 14
osidedan
You could do it with tuples in a sorted list in Python, but if you need it to be MEL I'm not sure how to do that. Here's the python version though just in case, might spark some ideas!
list_raw = ['8=geo32', '6=geo26', '3=geo87', '22=geo11', '1=geo3', '2=geo7']
list_as_tuples = []
for item in list_raw:
    split = item.split('=')
    list_as_tuples.append((int(split[0]),'=' + split[1]))
list_as_tuples.sort()
print (list_as_tuples)
list_stitched = []
for item in list_as_tuples:
    list_stitched.append(str(item[0]) + item[1])
print (list_stitched)
print output:[(1, '=geo3'), (2, '=geo7'), (3, '=geo87'), (6, '=geo26'), (8, '=geo32'), (22, '=geo11')]
['1=geo3', '2=geo7', '3=geo87', '6=geo26', '8=geo32', '22=geo11']
Message 7 of 14
malcolm_341
Thanks for the suggestion, but I need it to be mel to work in Maya LT.
Message 8 of 14
osidedan
oh wow, I had no idea that Maya LT was THAT limited. Just about every other "indie" version of pro 3d software out there still has Python scripting abilities. I mean, even the free versions of other 3D apps still have Python.  Seems like a terrible call by autodesk to limit something as simple as Python scripting.
well, either way, I wish you luck on your quest to solve your problem!
Message 9 of 14
AssassinKKD
string $array[] = {"8=geo32", "6=geo26", "3=geo87", "22=geo11", "1=geo3", "2=geo7"};
print(sort($array));
this prints
1=geo3
22=geo11
2=geo7
3=geo87
6=geo26
8=geo32
I think the sort function in mel only counts the first index of a string, sorry I don't have much knowledge in mel
Message 10 of 14
malcolm_341
Yes correct, as discussed above sort doesn's work on string numbers it only works on float numbers.
Message 11 of 14
tkaap2
MEL is a product of the time it was invented, so there are some extra steps to break down strings and reassemble them.  This procedure will sort your array.  The steps are what others here have described -- break each array element into an integer part and a string part, sort the integers, then reassemble the string parts back onto the integer parts, using the newly-sorted ordering.  Hopefully this helps!
global proc string[] sortIntStringArray(string $inputArray[])
	print("The input array is:\n");
	print($inputArray);
	print("\n");
	string $buffer[];
	int $arraySize = size($inputArray);
	// split the input array into a list of numbers.  Store the string
	// payloads off to the size until later.
	int $indexArray[];
	string $stringBufferArray[]; // holds the string payloads from the input
	int $numTokens = 0;
	int $i;
	int $integerFromString;
	for($i=0; $i < $arraySize; $i++)
		// split each input element into the part before '=' and the part after it.
		tokenize $inputArray[$i] "=" $buffer;
		// convert the string representation of the integer into an actual integer.
		$integerFromString = int($buffer[0]);
		// append the integer to an integer array.
		$indexArray[$i] = $integerFromString;
		// add the string payload to a string array, but use the integer portion as
		// the index into this (sparse) array so that we can retrieve it easily later.
		$stringBufferArray[$integerFromString] = $buffer[1];
	// Sort the list of just integer indices.  If all you need is the sorted list of integers,
	// use this.
	$indexArray=sort($indexArray);
	print("Found these indices:\n");
	print($indexArray);
	print("\n");
	string $stringArray[];
	//Now rebuild the string array using the sorted indices from $indexArray.
	for ($i=0; $i < size($indexArray); $i++){
		$stringArray[$i] = ($indexArray[$i] + "=" + $stringBufferArray[$indexArray[$i]]);
	// $stringArray is now the sorted-by-integer result of the input
	print("The sorted array is now:\n");
	print($stringArray);
	print("\n");
	// Return this array for other use.
	return $stringArray;
	// Call the sorting function with the example input array:
	$array = sortIntStringArray($array);
	print("The returned array is now:\n");
	print($array);
	print("\n");
The input array is:
8=geo32
6=geo26
3=geo87
22=geo11
1=geo3
2=geo7
1
2
3
6
8
22
1=geo3
2=geo7
3=geo87
6=geo26
8=geo32
22=geo11
1=geo3
2=geo7
3=geo87
6=geo26
8=geo32
22=geo11
Message 12 of 14
malcolm_341
Wow that's great thanks, I had already had the first part working tokenizing and stitching, but I couldn't figure out how to stitch them back in the right order after they were sorted.
Message 13 of 14
mcw0
I thought this was already sorted (pun intended).  If I knew you were still having trouble with the code, I would have provided it.  Sorry about that.
Message 14 of 14
malcolm_341
I solved my specific issue by ignoring names altogether and sorting by world space distance, but I still wanted to know how to do this for future scripts it's a handy technique.
