I wrote my own surfaceShape derived from MPxSurfaceShape. I can attach a shader and the shader is correctly displayed if I select the shape and let the shader display in the hypershade. It even renders fine, but for some reason I am unable to see it in the attributeEditor. Normal shapes display the attached shader at the right side in the attributeEditor, plugin shapes do not. I tried it with the apiMeshShape example and got the same result, no shader in the attributeEditor. is there any way to make the shader visible in AE?
