How to select shading group in Mel?
malcolm_341
malcolm_341
Hi, today I was surprised to find out I can't store a shading group in a variable and then use that variable to select it. I created a blinn shader and manually selected it's shading group node, then I ran in the script editor
string $temp[] = `ls -sl`;
select $temp;
And that doesn't select my shading group, is there something I'm missing here?
stephenkmann
Shading Groups,(SG) are sets
 When you select a set (using mel/python) , it selects the items in the set by default.
 ( this works this way for all sets)
but  ,if you want to select the set itself. you want to use the noExpand flag (-ne -noExpand )
so if you run
string $sel[] = `ls -sl`;
select -ne $sel;
but be aware that mel will return a single object from ls -sl if you have a single object. but an array , if you have multiple objects
so if you select multiple shaderGroups., you want to index the array
select -ne $sel[0];
select -ne $sel[1];
hth
-=s
malcolm_341
@stephenkmann   That did the trick, thanks! I didn't know about this set workflow.
