Announcements
How to rotate a node from a custom pivot - Maya API
143110913
143110913
On maya python api 2.0 I am trying to rotate a node from a custom pivot.
This is how it looks like inside Maya
And this is my code
import maya.OpenMaya as om
import maya.cmds as cmds
object_position = om.MVector(0.0, 1.0, 0.0)
pivot_pos = om.MVector(0.0, 0.0, 0.0)
twist_axis = om.MVector(0.0, 0.0, 1.0)
twist_value = 1
transform = om.MTransformationMatrix()
transform.setTranslation(object_position, om.MSpace.kWorld)
transform.setRotatePivot(
    om.MPoint(pivot_pos),
    om.MSpace.kWorld,
    True)
rotation_quat = om.MQuaternion(twist_value, twist_axis)
transform.rotateBy(rotation_quat, om.MSpace.kTransform)
final_pos = transform.translation(om.MSpace.kTransform)
cmds.spaceLocator(p=(final_pos.x, final_pos.y, final_pos.z))
Doesn't seem to rotate from the provided pivot,
What am I missing?
Thank you for your help!
brentmc
You are computing a transformation matrix but only applying the position to your newly created locator.
Instead you need to apply the whole transformation you created like this:
twist_value = 1
    om.MSpace.kWorld,
    True)
# create space locator at origin
locator = cmds.spaceLocator()
# convert command result to an MObject
selection = om.MSelectionList()
selection.add(locator[0])
object = om.MObject()
selection.getDependNode(0, object)
# Apply transform computed above to the locator
locatorXform = om.MFnTransform(object)
locatorXform.set(transform)
Brent McPherson
Principle Engineer
brentmc
P.S. Your example is Maya Python API 1.0. To use API 2.0 you need:
import maya.api.OpenMaya as om
Brent McPherson
Principle Engineer
That was it! Thank you for your help, Brent!
