How to make custom context in Maya API 2.0 receive flag/argument?
atxadaaldo17022
Message 1 of 1
atxadaaldo17022
Community Visitor
Community Visitor
Hello!,
Currently, I’m working on creating custom context using Maya API 2.0
I already searched from documentation and any tutorial I could find, but I don’t know how to get context command to receive flag/argument. The only closest reference I can get online is here helixTool.cpp. But it’s C++, and using Maya API 1.0 so I had a problem translating the code.
Below I already attach my progress so far, any help would be greatly appreciated!
-Aldo
# flag definition
kMeshFlag = "-m"
kMeshLongFlag = "-mesh"
# tell maya plugin produces and need to be passed, maya api 2.0
def maya_useNewAPI():
    pass
class CutomTool(omui.MPxToolCommand):
    mesh = None
    def __init__(self):
        super(CutomTool, self).__init__()
    def syntaxCreator(self):
        syntax = om.MSyntax()
        # (short name, long name, argument data type)
        syntax.addFlag(kMeshFlag,kMeshLongFlag,om.MSyntax.kString)
        return syntax
    def argumentParser(self, argList):
        syntax = self.syntax()
        parsedArguments = om.MArgParser(syntax, argList)
        if parsedArguments.isFlagSet(kMeshFlag):
            self.mesh = parsedArguments.flagArgumentString(kMeshFlag, 0)
            return om.MStatus.kSuccess
        if parsedArguments.isFlagSet(kMeshLongFlag):
            self.mesh = parsedArguments.flagArgumentString(kMeshLongFlag, 0)
    def doIt(self, argList):
        self.argumentParser(argList)
        if self.mesh != None:
            self.redoIt()
    def isUndoable(self):
        return True
    # action to undo operation
    def undoIt(self):
        print ("undo")
    def redoIt(self):
        print ("redo")
    def finalize(self):
        command = om.MArgList()
        command.addArg(om.MString(kMeshFlag))
        command.addArg(self.mesh)
        return omui.MPxToolCommand.doFinalize(command)
    @classmethod
    def creator(cls):
        return CutomTool()
class CustomContext(omui.MPxContext):
    TITLE = "Title"
    HELP_TEXT = "Help Text"
    def __init__(self):
        super(CustomContext, self).__init__()
        self.setTitleString(CustomContext.TITLE)
    def helpStateHasChanged(self, event):
        self.setHelpString(CustomContext.HELP_TEXT)
    def toolOnSetup(self,event):
        om.MGlobal.selectCommand(om.MSelectionList())  # select nothing, to record undo
        self.reset_context()
    def toolOffCleanup(self):
    def doPress(self, event, draw_manager, frame_context):
        print ("do press")
    def completeAction(self):
        print ("complete action")
    def deleteAction(self):
        print ("undo")
    def abortAction(self):
        print ("abort")
    def reset_context(self):
        print ("reset")
class CustomContextCmd(omui.MPxContextCommand):
    COMMAND_NAME = "customCommand"   # used as mel command to create context
    def __init__(self):
        super(CustomContextCmd, self).__init__()
    # required for maya to get instance of context
    def makeObj(self):
        return CustomContext()    # return ribbon spline ctx
    @classmethod
    def creator(cls):
        return CustomContextCmd() # return ribbon spline ctx cmd
def initializePlugin(plugin):
    plugin_fn = om.MFnPlugin(plugin)
    try:
        plugin_fn.registerContextCommand(CustomContextCmd.COMMAND_NAME,
                                         CustomContextCmd.creator)
    except:
        om.MGlobal.displayError("Failed to register context command: %s"
                                 %CustomContextCmd.COMMAND_NAME)
def uninitializePlugin(plugin):
    try:
        plugin_fn.deregisterContextCommand(CustomContextCmd.COMMAND_NAME)
    except:
        om.MGlobal.displayError("Failed to deregister context command: %s"
Replies (0)
