How to make a persistent menu on a panel?
manuel.spkDKCCG
manuel.spkDKCCG
Hi!
I'm trying to add a new menu on the Camera Sequencer's (or any other window) menu bar.
I'm using this command, as I read on the documentation:
cmds.menu( label='Tools', parent="sequenceEditorPanel1")
And this works great. When I execute It, I can see my new menu called "Tools" on the Camera Sequencer window.
The only problem comes, when I close this Window, and opened It again, the menu has gone away.
So... Do I have to call this line everytime I open my Camera Sequencer Window? If so... How can I do this?
Is there any way to make this menu persistent?
Thanks!
tdHendrix
Maya has a file that it runs at startup called userSetup.py. You can put your code in there and it should show up every time you open Maya.
My userSetup.py directory is here: C:\Users\your.name\Documents\maya\scripts
Greg Hendrix - Senior Technical Animator
LinkedIn : Twitter
manuel.spkDKCCG
Thanks! But I guess that would not solve my problem, because my menu is disapearing everytime I close the Camera Sequencer Window... not the Maya Window.
If this can help someone, I've come to this (not optimal, I guess) solution, based on other solutions I've found. While Maya is in Idle state, is constantly asking if Camera Sequencer is opened. When It's opened, It adds the Tools Menu on the window.
import maya.cmds as cmds
import pymel.core as pm
class WindowWatcher():
    """ A class to watch for a particular window in Maya """
    def __init__(self, window_name, on_open_callback, on_close_callback=None):
        self.window_name = window_name
        self.on_open_callback = on_open_callback
        self.on_close_callback = on_close_callback
        self.window_opened = False
    def check_for_window_open(self):
        if not self.window_opened:
            if self.window_name in cmds.getPanel(vis=1):
                self.on_open_callback.__call__()
                self.window_opened = True
        else:
            if not self.window_name in cmds.getPanel(vis=1):
                if self.on_close_callback:
                    self.on_close_callback.__call__()
camera_sequencer_name = "sequenceEditorPanel1"
def on_open_camera_sequencer():
    # your on_window_open code here
    cmds.menu( label='Tools', parent="sequenceEditorPanel1", tearOff = True)
camera_sequencer_watcher = WindowWatcher(camera_sequencer_name, on_open_camera_sequencer)
cmds.scriptJob(event=["idle", pm.windows.Callback(camera_sequencer_watcher.check_for_window_open)])
I'm pretty sure there's a better way to do this, but I couldn't find It. If someone knows a better solution, pls, I'd love to know.
Thanks!
