How to get Maya's main window with Python API 2.0?
g2m.agent
g2m.agent
This code is provided in the manual:
from maya import OpenMayaUI as omui
omui.MQtUtil.mainWindow()
ptr = omui.MQtUtil.mainWindow()
but in Python API 2.0, there is no "MQtUtil".
Therefore, my conclusion is that if you want to use Python API2.0, you cannot use PySide2.
Is that right?
zewt
I don't know if there's a separate OM2 binding, but you can just use OM1 for this.  Since this is just giving you a pointer to a Qt object, it's fine to use OM1 here even if you also have OM2 code.
