Announcements
How to extract or generate thumbnail for Maya files?
I would like to extract or generate thumbnails for given *.mb files on macOS and/or Windows.
1) Does Maya embed a thumbnail of the viewport upon saving into *.mb files?
2) Is there any way to extract or generate such image programatically or with a helper process?
I have the same situation with Photoshop files, where I can generate such small thumbnail with `libpsd`. Does something similar exist for Maya as well?
Thank you!
stuzzz
I've done that a long time ago.
- set a callback when maya save a scene which triggers a function
- That function is calling a QPixmap method to capture the focused viewport.
Hi, thank you very much! Unfortunately I am looking for a solution that works where Maya is not installed (or at least not running anymore).
mspeer
Hi!
The only option is to create sidecar files or add thumbnails to a special sub-folder in the project directory, however without Maya installed you can't render preview images.
Oh, I see. Because most 3D applications save a viewport image inside the file upon saving, so that's unfortunate to hear it doesn't work with Maya. But thanks for the confirmation!
mspeer
Hi!
To create and use preview images in Maya please check this:
https://help.autodesk.com/view/MAYAUL/2020/ENU/?guid=GUID-67B3FB68-AAA4-415D-A37B-1EAC461613C0
Cool! That looks very promising. Would be good if that could be done automatically, but that looks like what I need! 🙂
