How to export a custom attribute on alembic export attached to the actual AlembicNode?
sophia.berger966CF
sophia.berger966CF
Hello, I am having a bit of an issue exporting a custom attribute. I add the attribute via
cmds.addAttr("myAttrName")
then set using
cmds.setAttr("myAttrName", myValue)
then finally add the custom flag
-attr myAttrName -userAttr myAttrName
on export using the cmds.AbcExport option. This does export the attribute, but on the geometry for the imported alembic, and not the actual AlembicNode. I would like that attribute to show up on the AlembicNode itself (under the "Extra Attributes" tab) but I can't figure out how to get that to happen. Is there a way to achieve this using the alembic python module, or better yet, within Maya?
Kahylan
Hi!
Sadly I don't think this is possible, atleast not while exporting. The Alembic Node is just created when it is exported, so you can't really add any attributes to it beforehand and the AbcExport command only has flags to write attributes onto the geometry.
What you could do, is create a script for importing your alembic that automatically adds the attribute to the alembic Node after it is imported...
What do you need this attribute for?
sophia.berger966CF
It's just an integer that is meant to pass a value through our pipeline, it was requested it be on the alembic node - I'm trying to see if there's a way to modify the alembicNode post export via alembic's OArchive but I think your solution is probably better
madugundikau
Community Visitor
Community Visitor
Is it possible to import values to custom attributes using script?
for example I have 3 custom attributes
attribute    Minimum value    Maximum value
  p1                      0                               1
  p2                      0                              1
  p3                     0                               1
with its range
now I have to pass below shown values to that custom attributes. is there any script for this?
{p1  0.1,     p2  0.4 ,    p3  0.3
 p1  0.4 ,    p2  0.2  ,   p3  0.5
 p1  0.5,     p2  0.5 ,    p3  0.1
 p1  0.3      p2  0.5      p3  0.5}
script as to read 1st set of parameters values (p1 0.1,    p2 0.4 ,    p3 0.3) and save the files in STL format
again script as to read 2nd set of values(p1  0.4 ,   p2  0.2,    p3  0.5) and save the file in STL format and continue the set for parameters values
Please help me with this script
