how to change the render filter via command
Amit_Karny_עמית_קרני
Hey there!
I do have plenty of scene I should change it filter via Arnold render.
I look for any simple new shelf item with a command.
to this end I tried either
setAttr "defaultArnoldFilter.type" 12;
setAttr "defaultArnoldFilter.width" 2;
 or
setAttr "defaultArnoldFilter.type" contour;
 but none of them had change the type.
Maya 2020.
Thanks in advance.
Kahylan
Hi!
This is the command you are looking for:
setAttr -type "string" "defaultArnoldFilter.aiTranslator" "contour" ;
By the way, here is a handy script to just print out every attribute on a node plus the value currently assosiated with it, it helps a lot in finding weirdly named attributes:
proc attrValues(string $node){
    string $attrs[] = `listAttr $node`;
    for ($a  in  $attrs){
        if ($a != "message"){
            $v = getAttr ($node +"."+ $a);
            print($a + ":" + $v + "\n");
attrValues("defaultArnoldFilter")
I hope it helps!
Thanks a lot!!! Works perfect.
