Announcements
How to add many MRenderItem's in a MRenderItemList?
I have an MPxGeometryOverride and need to create many MRenderItems. I append them render item by renter item in the MRenderItemList during a loop.
However beyond 3 or 4000 it becomes quite slow and reaching the 10'000 takes ages.
Is there a way to bulk add all render items in one go, or is there another way to do ?
Putting all my geometry in a single renderitem is not really a solution.
Thanks !
cheng_xi_li
Autodesk Support
Autodesk Support
I am afraid there is no way to bulk add renderitems. If they are same renderItem with different transforms, it would be better to use MPxSubsceneOverride which supports instancing.
Yours,
Li
Ok, thanks, will look into MPxSubsceneOverride !
Hi Li,
I played with MPxSubsceneOverride and performance is indeed much better.
However 1 issue I have: How can I force update (instead of changing time) ?
Thanks !
cheng_xi_li
Autodesk Support
Autodesk Support
You'll need to trigger an update (e.g. MPlug::getValue).
Yours,
Li
Oh thanks, it works 🙂 !!
