Announcements
How to access UUID with C++ API?
I’m writing a plugin in C++ and need to get the UUID of the selected node. When I create a shape, a NURBS Cube for example, I see the UUID attribute is in the Attribute Editor. I also have found that you can use the MEL command “ls -uuid [node name]” to get it to print to the MEL Result box. However, I need access to this data from within the C++ code I’m writing.
I’m reading about plugs and attributes, so I think I’m on the right path, but I’m still having some trouble. Any guidance or help would be much appreciated.
stuzzz
I've tried or tested but reading the doc, this would help:
//create your MObject() containing your node here
mfn = MFnDependencyNode(obj);
MUuid myuuid = mfn.uuid();
myuuid.asString();
please let me know.
