How do I change the order in which plugins are loaded?
In Maya, some plugins are loaded automatically. One of the plugins automatically generates an error when loading. If you load this plugin manually, there are no errors. I would like to know where the script that controls the loading of plugins in Maya is to put this plugin to load last.
rajasekaransurjen
You can find a file called "pluginPrefs.mel" from "Documents\maya\2018\prefs" this file may be help you.
