How can i get menuItems parent?
I want to create custom menu on main window menubar, and radio button on it.
I don't know how to get the status of radio button on callback function, so I tried to get parent menu from menu item, but I got stuck because querying parent on menu item is failed.
import maya.cmds as mc
import maya.mel as mel
def checkStatus(menuItem) :
# below statement failed with
# Error: RuntimeError: file <maya console> line 6: No flags found that can be queried. parent = mc.menuItem(menuItem, query=True, parent=True) collection = mc.menuItem(menuItem, query=True, collection=True) for item in mc.menu(parent, query=True, itemArray=True) : if mc.menuItem(menuItem, query=True, isRadioButton=True) and mc.menuItem(item, query=True, collection=True) == collection : if mc.menuItem(item, query=True, radioButton=True) : break else : print('could not find ON status radio button.') print('%s : %s' % (collection, mc.menuItem(item, query=True, label=True))) gMainWindow = mel.eval('$tmpVar = $gMainWindow') menuId = 'Test_Menu' if mc.menu(menuId, exists=True) : mc.menu(menuId, edit=True, deleteAllItems=True) else : mc.menu(menuId, label='My Menu', parent=gMainWindow) mc.menuItem('divider1', divider=True, dividerLabel='like apple?', parent=menuId) collection1 = 'collectionYesNo' mc.radioMenuItemCollection(collection1, parent=menuId) mc.menuItem('menu_item1', label='Yes', radioButton=True, command='checkStatus("menu_item1")', sourceType='python', parent=menuId) mc.menuItem('menu_item2', label='No', radioButton=False, command='checkStatus("menu_item2")', sourceType='python', parent=menuId) mc.menuItem('divider2', divider=True, dividerLabel='Most like?', parent=menuId) collection2 = 'collectionChoiceOne' mc.radioMenuItemCollection(collection2, parent=menuId) mc.menuItem('menu_item3', label='Tennis', radioButton=True, command='checkStatus("menu_item3")', sourceType='python', parent=menuId) mc.menuItem('menu_item4', label='Soccor', radioButton=False, command='checkStatus("menu_item4")', sourceType='python', parent=menuId) mc.menuItem('menu_item5', label='Baseball', radioButton=False, command='checkStatus("menu_item5")', sourceType='python', parent=menuId) mc.menuItem('menu_item6', label='Valleyball', radioButton=False, command='checkStatus("menu_item6")', sourceType='python', parent=menuId)
How can i get parent UI ? (or how can i get radiobutton menuItem status?)
lee.dunham
You could probably use the collection flag to query the radioButtonCollection it belongs to (and then get the current state).
To address the issue you're experiencing, the parent flag isn't query-able (no Q next to it in documentation), which would explain your error.
hi lee
I could get radioMenuItemCollection, but the element does not have "select" or  "collectionItemArray" radioCollection have.
