Announcements
How can I find deformed mesh vertices?
I'm new to maya and I'm trying to write a script that creates a lattice deformation and deforms a mesh up until a certain point and then stops. I'm able to query the vertices of my mesh, but not sure how to get the coordinates of the deformed mesh vertices
An example of what I'm trying to do:
maya.lattice(model_name, dv=(5, 2, 5), ldv=(5, 2, 5), objectCentered=True)
maya.select('ffd1Lattice.pt[0][0:1][0]')
maya.move(-0.5, 0, 0, relative=True)
maya.select('ffd1Lattice.pt[4][0:1][0]')
maya.move(0.5, 0, 0, relative=True)
children = maya.listRelatives(model_name, allDescendents=True, noIntermediate=True, fullPath=True)
meshes = maya.ls(children, type="mesh")
for mesh in meshes:
     mesh_verts = maya.xform(mesh + '.vtx[*]', ws=True, t=True)
# Not sure how to find this: deformed_verts = maya.xform(*lattice mesh output* + '.vtx[*]', ws=True, t=True)
Could anyone help me find a way to approach this?
tony.su
Autodesk Support
Autodesk Support
You can try this.
import maya.cmds as cmds
cmds.polySphere();
cmds.lattice(dv=(5, 2, 5), ldv=(5, 2, 5), objectCentered=True)
children = cmds.listRelatives("pSphere1", allDescendents=True, noIntermediate=True, fullPath=True)
meshes = cmds.ls(children, type="mesh")
for mesh in meshes:
mesh_verts = cmds.xform(mesh + '.vtx[203]', q=True, ws=True, t=True)
print mesh
print mesh_verts
cmds.select('ffd1Lattice.pt[0][0:1][0]')
cmds.move(-0.5, 0, 0, relative=True)
cmds.select('ffd1Lattice.pt[4][0:1][0]')
cmds.move(0.5, 0, 0, relative=True)
for mesh in meshes:
print mesh
print mesh_verts
The result as follow:
pSphereShape1
[0.3052126467227936, 0.15643437206745148, -0.9393479228019714]
pSphereShape1Orig
pSphereShape1
[0.37895670533180237, 0.15643437206745148, -0.9393479228019714]
pSphereShape1Orig
You will find two shapes, pSphereShape1 and pSphereShape1Orig. pSphereShape1 is the shape and pSphereShape1Orig is the original lattice shape. You can get position of deformed shape from pSphereShape1, and get position of original shape from pSphereShape1Orig.
Tony Su
Product Support
