Help with setParent
Help with setParent
samunawa
Help with setParent
samunawa
Hi there. I'm trying to get to grips with the setParent command but I can't get it to work! Heres my example code that I'm testing this with:
string $window = `window -t "Shape Spawner" -wh 560 500`;
        rowLayout -numberOfColumns 2;
            button -label "Delete All" -command "select -cl; MTselAll; doDelete";
        setParent..;
    setParent..;
    gridLayout -numberOfColumns 8 -cellWidthHeight 70 50;
            symbolButton -image "polySphere.xpm" -command "polySphere;";
            symbolButton -image "polyCube.xpm" -command "polyCube;";
            symbolButton -image "polyCylinder.xpm" -command "polyCylinder;";
            symbolButton -image "polyCone.xpm" -command "polyCone;";
            symbolButton -image "polyPlane.xpm" -command "polyPlane;";
            symbolButton -image "polyTorus.xpm" -command "polyTorus;";
            symbolButton -image "polyPyramid.xpm" -command "polyPyramid;";
            symbolButton -image "polyPipe.xpm" -command "polyPipe;";
        setParent..;
    setParent..;
showWindow $window
And heres whats happening:
c7f715e2e2854161b013d7a87105bbf1
I need the "delete all" button to be ontop but I cant get this working. Do I have to create a string which defines what the 'top' is and implement that into my setParent? Thanks.
Hi samunawa
The problem isn't in the way you are using setParent, but its actually because you are using the wrong layout type. A rowLayout is used to place items in a row next to one another. What you need is a columnLayout which puts things in a column on top of one another, like this:
// columnLayout puts items on top of one another
columnLayout -adjustableColumn true;
// First item in the columnLayout
// Second Element in the columnLayout
setParent ..;
setParent ..;
showWindow $window
The -adjustableColumn true part makes the column stretch to fit its parent container, so in this case it makes the button stretch with the window.
Its also worth pointing out that strictly speaking you don't actually need the last two setParent calls, unless you are planning on adding more UI after the gridLayout. However it is good practice to always pop back to the parent layout to avoid confusion when you come to modify the code at a later date.
Hope this helps
Mike.
samunawa
Ah yes you've explained it better than my teacher haha, thank you 🙂
