Group instead a curve
cgartistbox
cgartistbox
import maya.cmds as cmds
import os
Duplicate object(s) and convert it/them into prop
def create_circular_shapes_and_groups():
    # Get selected objects
    selected_objects = cmds.ls(selection=True)
    if not selected_objects:
        cmds.warning("No hay objetos seleccionados.")
        return
    # Get bounding box selection
    bounding_box = cmds.exactWorldBoundingBox(selected_objects)
    # Calculate BB radius
    radius = max(bounding_box[3] - bounding_box[0], bounding_box[5] - bounding_box[2]) / 2.0
    # create group local
    group_local = cmds.group(em=True, name="group_local")
    # Create shape local
    circle_local = cmds.circle(name="local_shape", center=(0, 0, 0), normal=(0, 1, 0), radius=radius)[0]
    # parent local to group local
    cmds.parent(circle_local, group_local)
    # Yellow local
    shape_node_local = cmds.listRelatives(circle_local, shapes=True, fullPath=True)[0]
    cmds.setAttr(f"{shape_node_local}.overrideEnabled", 1)
    cmds.setAttr(f"{shape_node_local}.overrideColor", 17)
    # Parent selected objects to local
    cmds.parent(selected_objects, circle_local)
    # Create group world
    group_world = cmds.group(em=True, name="group_world")
    # Create shape world 110% bigger
    radius_world = radius * 1.1
    circle_world = cmds.circle(name="world_shape", center=(0, 0, 0), normal=(0, 1, 0), radius=radius_world)[0]
    # Parent circle world to group_world
    cmds.parent(circle_world, group_world)
    # Yellow to world
    shape_node_world = cmds.listRelatives(circle_world, shapes=True, fullPath=True)[0]
    cmds.setAttr(f"{shape_node_world}.overrideEnabled", 1)
    cmds.setAttr(f"{shape_node_world}.overrideColor", 17)
    # Parent group_local to world
    cmds.parent(group_local, circle_world)
# Duplicate special selection
def duplicate_special():
    # Get selection
    # Check if there is a selection
    if selected_objects:
        # Duplicate Special
        # 'rr' (return roots) avoid reference duplication, create local object
        duplicates = cmds.duplicate(selected_objects, rr=True)
        selected_objects = duplicates
        # Isolate objects
        cmds.isolateSelect(cmds.paneLayout('viewPanes', q=True, pane1=True), state=1)
        cmds.isolateSelect(cmds.paneLayout('viewPanes', q=True, pane1=True), addSelected=True)
        # Return the duplicated objects
        return selected_objects
    else:
        print("No objects selected.")
        return None
# Locator to selection
def locator_to_edit_selection(selected_objects):
        cmds.warning("No selection.")
        return
    # Bounding box boundaries
    # Calculate x,z and Y to ground
    center_x = (bounding_box[0] + bounding_box[3]) / 2.0  # X center
    center_z = (bounding_box[2] + bounding_box[5]) / 2.0  # Z center
    min_y = bounding_box[1]  # Lower Y
    # Create locator in the center
    locator = cmds.spaceLocator(name="handle")[0]
    cmds.xform(locator, worldSpace=True, translation=(center_x, min_y, center_z))
    # Parent objects to locator
    cmds.parent(selected_objects, locator)
    # Geometry not selectable
    for obj in selected_objects:
        cmds.setAttr(f"{obj}.overrideEnabled", 1)  # Activate override
        cmds.setAttr(f"{obj}.overrideDisplayType", 2)  # Not selectable
    # Move locator to origin and freeze transforms
    cmds.xform(locator, worldSpace=True, translation=(0, 0, 0), rotation=(0, 0, 0), scale=(1, 1, 1))
    cmds.select('handle')
    cmds.setToolTo('Rotate')
    # Focus to object
    cmds.viewFit()
    # Return the updated selection
# Create reference
def create_reference(selected_objects):
        cmds.warning("No selected objects")
        return
    # Parent the objects to the world and freeze transformations
    cmds.parent(selected_objects, world=True)
    cmds.makeIdentity(selected_objects, apply=True, translate=True, rotate=True, scale=True, normal=False)
    cmds.delete('handle')
    # Ask for path and file name
    export_path = cmds.fileDialog2(fileFilter="Maya ASCII (*.ma)", dialogStyle=2, fileMode=0)
    # No file, no job
    if not export_path:
        cmds.warning("No se seleccionó ninguna ruta de exportación.")
        return
    # fileDialog2 returns a list, so we need to extract the first item (the path)
    export_path = export_path[0]
    # Name as namespace
    file_name = os.path.splitext(os.path.basename(export_path))[0]
    # Export objects to the selected path
    cmds.file(export_path, exportSelected=True, type="mayaAscii")
    # Delete the selected objects from the scene
    cmds.delete(selected_objects)
    # Reference the exported file back into the scene with the file name as the namespace
    cmds.file(export_path, reference=True, namespace=file_name)
    current_panel = cmds.getPanel(withFocus=True)
    # Deactivate isolate
    if cmds.getPanel(typeOf=current_panel) == "modelPanel":
        cmds.isolateSelect(current_panel, state=False)
    # Close the window
    cmds.deleteUI('customWindow', window=True)
    cmds.delete('group_world')
# Export reference
def export_reference(selected_objects):
    # Check if the window already exists and delete it if necessary
    if cmds.window('customWindow', exists=True):
    # Create pop-up window
    window = cmds.window('customWindow', title="Orient the prop", widthHeight=(400, 400))
    cmds.columnLayout(adjustableColumn=True)
    # Text instruction
    cmds.text(label="Please, set up the prop correctly and press Finish.")
    # Button to execute the reference creation
    cmds.button(label="Finish", command=lambda *args: create_reference(selected_objects))
    # Show the window
    cmds.showWindow(window)
# Main workflow
# Step 1: Duplicate special selection
selected_objects = duplicate_special()
# Step 2: Create locator and parent the duplicates to it
selected_objects = locator_to_edit_selection(selected_objects)
# Step 3: Export reference using the selected objects
This code should create a copy of selected objects from a scene to adjust their rotation in the origin and create curves as controllers. But the world_shape is a group not a curve... how could I fix it? I know it's something about transforms and shapes but I'm lost right now. Any help?Captura.JPG
mcw0
Place some checks and prints in your code to find the issue.  After creating the world shape, verify that you have a nurbsCurve.  Then each step after that, again verify that there is still the same nurbsCurve.  Print the result at each check to find when the nurbsCurve disappears.
