Getting syntax error when trying to run this expression before dynamics
miguel.m6805
Observer Observer
miguel.m6805
Observer
Observer
Here's what's giving me a syntax error line 11:63. Please help
vector $position = nParticleShape2.position ;
if ( $position.y > locator_triggerDistance1.translateY) {
nParticleShape2.trigger = 1 ;
nParticleShape2.rgbPP = << 0,nParticleShape2.trigger, 0 >> ;
float $speedOfGoalChange = .025 ;
if ( nParticleShape2.trigger == 1) {
nParticleShape2.goalWeight0PP = nParticleShape2 .goalWeight0PP - $speedOfGoalChange ;
nParticleShape2.goalWeight1PP = nParticleShape2.goalWeight1PP + $speedOfGoalChange ;
nParticleShape2.goalWeight0PP = max ( 0, nParticleShape2.goalWeight0PP ) ;
nParticleShape2.goalWeight1PP = min ( 1, nParticleShape2.goalWeight1PP ) ;
nParticleShape2.turbulenceField1_magnitude = 1200 * ( sin (nParticleShape2.goalWeight1PP * 3.14) ) ;
mcw0
Without running it, it looks fine.  The only thing I would change is to combine this section.
To:
nParticleShape2.goalWeight0PP = max(0, (nParticleShape2 .goalWeight0PP - $speedOfGoalChange)) ;
nParticleShape2.goalWeight1PP = min(1, (nParticleShape2.goalWeight1PP + $speedOfGoalChange)) ;
Try running your expression part by part to isolate the problematic line.
Kahylan
Hi!
there is a space before the dot in "nParticleShape2 .goalWeight0PP" that is causing the synthax error, change it to "nParticleShape2.goalWeight0PP" and it should work.
I hope it helps!
mcw0
@Kahylan Great Catch!
