Getting dockableWorkspaceWidget to auto dock to channel box tab area
Craig_Lamorte
Craig_Lamorte
I am working off the dockableWorkspaceWidget.py from the maya devkit.  I am trying to get it so that it will automatically dock the window into the workspace that the channelbox and attribute editor are located.  I have tried adding an area=right and floating=false flag.  like this -
customMixinWindow.show(dockable=True, area='right', floating=False, height=900, width=400, uiScript='DockableWidgetUIScript(restore=True)')
Which does make it dock on startup, but it docks it to the right of the channel box workspace, and shoves that workspace to the left of it.  I do not want this, how do i get it to dock in the proper workspace?
For reference here is the original cod from dockableworkspacewidget.py
# Copyright 2017 Autodesk, Inc. All rights reserved.
# Use of this software is subject to the terms of the Autodesk license
# agreement provided at the time of installation or download, or which
# otherwise accompanies this software in either electronic or hard copy form.
from maya.app.general.mayaMixin import MayaQWidgetDockableMixin
from maya import OpenMayaUI as omui
from PySide2.QtCore import *
from PySide2.QtGui import *
from PySide2.QtWidgets import *
customMixinWindow = None
''' MayaQWidgetDockableMixin is not a workspace control in itself, it is added
    as a child to a created workspace control. See help(MayaQWidgetDockableMixin)
    for more details. The following class is a simple widget with a layout and  a push button.
class DockableWidget(MayaQWidgetDockableMixin, QWidget):
  def __init__(self, parent=None):
    super(DockableWidget, self).__init__(parent=parent)
    self.button1 = QPushButton()
    self.button1.setText('PushMe')
    layout = QVBoxLayout()
    layout.addWidget(self.button1)
    self.setLayout(layout)
    self.setWindowTitle('Custom Maya Mixin Workspace Control')
''' A workspace control is created by calling show() on the DockableWidget class.
    This control is only created once if the retain property is set to true, which
    is the default. The uiScript argument passed to the show() method will be
    invoked every time this control is opened/restored. It is recommended to add
    the proper import statement in the uiScript argument.
    For example, in renderSetup.py file the UIScript for renderSetupWindow is
      "uiScript='import maya.app.renderSetup.views.renderSetup as renderSetup\nrenderSetup.createUI(restore=True)'"
    The following method needs to be invoked in order to create the workspace control for the example above.
    If the control is being restored, then Maya will call the method by passing restore=True
def DockableWidgetUIScript(restore=False):
  global customMixinWindow
  ''' When the control is restoring, the workspace control has already been created and
      all that needs to be done is restoring its UI.
  if restore == True:
	  # Grab the created workspace control with the following.
      restoredControl = omui.MQtUtil.getCurrentParent()
  if customMixinWindow is None:
	  # Create a custom mixin widget for the first time
      customMixinWindow = DockableWidget()
      customMixinWindow.setObjectName('customMayaMixinWindow')
  if restore == True:
	  # Add custom mixin widget to the workspace control
      mixinPtr = omui.MQtUtil.findControl(customMixinWindow.objectName())
      omui.MQtUtil.addWidgetToMayaLayout(long(mixinPtr), long(restoredControl))
  else:
	  # Create a workspace control for the mixin widget by passing all the needed parameters. See workspaceControl command documentation for all available flags.
      customMixinWindow.show(dockable=True, height=600, width=480, uiScript='DockableWidgetUIScript(restore=True)')
  return customMixinWindow
''' Using the workspaceControl Maya command to query/edit flags about the created
    workspace control can be achieved this way:
        maya.cmds.workspaceControl('customMayaMixinWindowWorkspaceControl', q=True, visible=True)
        maya.cmds.workspaceControl('customMayaMixinWindowWorkspaceControl', e=True, visible=False)
    Note that Maya automatically appends the "WorkspaceControl" string to the
    workspace control child object name. In this example it is the child widget name (customMayaMixinWindow)
def main():
    ui = DockableWidgetUIScript()
    return ui
if __name__ == '__main__':
    main()
Craig_Lamorte
figured it out.  after this line
I added this line
        cmds.workspaceControl('customMayaMixinWindowWorkspaceControl', e=True, ttc=["AttributeEditor", -1], wp="preferred", mw=200)
I do have one more issue though.  If I leave the this UI open and close maya and then re open maya, the UI is re opened (which I do not want it to do) but none of the buttons are UI elements are showing up.  If i try to relaunch the UI i get a
Object's name 'customMayaMixinWindowWorkspaceControl' is not unique. #
Looks like maya is remembering this UI and obviously won't let me create it again.  Is there an easy way to completely delete this UI when maya is closed / ui is closed?
