Get color per face/vertex?
So I have a sphere that I've assigned the default ramp to (blue - green - red) and I'm trying to obtain the color at each vertex; HOWEVER, when I call cmds.polyColorPerVertex() every vertex's color is black (0,0,0), unless I set it using the same command first.
Is there a way to sample color by vertex (or face) from a poly object stricly based off of it's shader's properties?
- forni
You should use the colorAtPoint command instead.
Given a point on the surface of my shape (ie. a vertex in this case) how do I obtain the UV coordinates of corresponding point in world space so that I may use color at point? Is there an easy way to do this?
kurianos
import maya.cmds as cmds
def getSelectedVertexColor(colorNode):
getCurrentVertex=cmds.ls(sl=True)
for eachVertex in getCurrentVertex:
convertVTX = cmds.polyListComponentConversion(eachVertex,fromVertex=True,toUV=True)
getUVValue = cmds.polyEditUV(convertVTX,q=True)
getVertexColorVal=cmds.colorAtPoint(colorNode,o='RGB',u=getUVValue,v=getUVValue)
print getVertexColorVal
getSelectedVertexColor('ramp1')
hope will help you
