Get children in menu does not work in Maya 2020, but in 2019
Hey,
I had a script that gets the children in a menu:
print cmds.menu('mainFileMenu', query = True, itemArray = True)
This works perfectly in Maya 2019 and returns a list with all the children, but in Maya 2020 the result is None, why is this the way?
Can someone please help!
mspeer
Hi!
Have you opened the File menu at least once in Maya 2020 before using this command?
Here it works the same as in Maya 2019.
zewt
You can force the menu to be built by running buildFileMenu.  You can see the others in scripts/startup/initMainMenuBar.mel.
