find the translate Attribute or position of Special objects in different frames
egoldid1
egoldid1
hi. How do I find the translate Attribute or position  of Special objects in different frames while I am on frame one?
The point is that The position of our object depends on several nodes connected to it.
brentmc
The question is a little vague so I'm not sure whether you are trying to do this at script or node level?
In scripting you can use the "getAttr -time" option to retrieve attribute values at a different frame than the current one.
Brent
Brent McPherson
Principle Engineer
jmreinhart
Depending on how your rig is set up, you may be able to use the frameCache node.
