Expression editor changes from Maya 2015 to 2018
I am trying to evaluate a simple expression every frame inside Maya 2018, but the result is wrong.
The funny part is that the same expression is working in Maya 2015.
Here is my expression :
vector $location = << mainControl.translateX, mainControl.translateY, mainControl.translateZ >>;
vector $oldlocation;
if(frame == 0)
    $oldlocation = $location;
float $speed = mag($location - $oldlocation);
print($oldlocation);
print("\n");
I am just trying to get the speed of  an object in movement.
In Maya 2015, oldlocation (which I print) is changing as expected.
In Maya 2018, its always 0. It seems like declaring $oldlocation sets it to (0,0,0).
How am I supposed to get the speed of the object in Maya 2018 ?
mspeer
Hi!
Your re-initialize $oldlocation every time the script runs, only at frame 0 the correct value will be assigned.
Thank you for your response.
How can I declare my variable $oldlocation only once, at the beginning ?
I can't declare it in an if statment, compiler won't accept it.
I still don't know how to get the speed of my object in maya 2018.
mspeer
Hi!
Any declaration outside of the expression will work fine.
Yes this I working!
So I added a new hidden attribute to my object, I hope this is what you meant..
Thank you so much!
mspeer
Hi!
Yes, that's one possible solution.
stephenhewett3d
Observer
Observer
Hi!
I believe I'm having a similar issue with the expression editor except my issue involves getting the frame and using it as an expression of time, I know this syntax works because I've seen it in earlier versions of maya
float $transx;
float $mult;
$transx = go2.tx - ('getAttr -t (frame -3) go2.tx');
if ($transx > .1) $mult = go1.drive;
else #mult = go1.drive * 1.3;
go2.tx = ($mult * ('getAttr -t (frame -3) go2.tx'))+3;
or preferably
go2.tx = 'getAttr -t (frame-(go1.drive))go1.tx'
go3.tx = 'getAttr -t (frame-(go1.drive*2))go1.tx'
I'm just trying to get 'go2' to repeat the animation that 'go1' has made with 'drive' frames as a delay number
and multiplying that number for 'go3'
