Error when using old Mel script
Hi everyone. I'm new to Maya and was going to follow along with a tutorial from pluralsight. The author has you download some free scripts from comet-cartoons to use while following along with the tutorial. Unfortunately they don't seem to work with the newest update of Maya. Or at least not mine. I don't know anything about scripting but i did copy the script to see if anyone could see why its want working. At execution of the script it is supposed to bring up a menu but the menu never loads. Thanks for any help.
// cometJointOrient.mel - MEL Script
// DESCRIPTION:
//    A nicer utility for setting rotation axis and aiming of joints
//    automatically.
// REQUIRES:
//    Nothing.
// USAGE:
//    source "cometJointOrient.mel"; cometJointOrient();
// AUTHORS:
//    Michael B. Comet - comet@comet-cartoons.com
//    Copyright ©2004 Michael B. Comet - All Rights Reserved.
// VERSIONS:
//    1.00 - Feb 21, 2004 - Initial Release.
//    1.01 - Feb 21, 2004 - Added dot check for up vector so that it will
//        stop the up vector from flipping in cases where the bones go
//        up and then down.
//    1.02 - Sep 17, 2004 - Added + and - tweak buttons, and right click on tweak.
//    1.03 - April 10, 2005 - Fixed so only unparents transform/joint not shapes.
global string $cJO_version = "1.03" ;
global string $cJO_date = "Apr 10, 2004" ;
 * cometJointOrient() - Main UI entry.
global proc cometJointOrient()
    global string $cJO_version ;
    global string $cJO_date ;
    if (`window -ex cometJointOrientWin` != true)
    window -w 310 -h 256 -t ("cometJointOrient - "+$cJO_version) -in "cometJointOrient" -s true -tb true cometJointOrientWin;
    formLayout mainForm ;
    separator -style "in" -h 3 sep0 ;
    button -l "Show Axis" -h 18 -al "center" -c ("toggle -state on -localAxis; ") -ann ("Show Local Axis") btnShow ;
    button -l "Hide Axis" -h 18 -al "center" -c ("toggle -state off -localAxis; ") -ann ("Hide Local Axis") btnHide ;
    radioButtonGrp -l "Aim Axis:" -nrb 3 -la3 "X" "Y" "Z" -sl 2 -cw4 80 40 40 40 rbgAim ;
    radioButtonGrp -l "Up  Axis:" -nrb 3 -la3 "X" "Y" "Z" -sl 1 -cw4 80 40 40 40 rbgUp ;
    checkBox -l "Reverse" -v 0 cbRevAim ;
    checkBox -l "Reverse" -v 0 cbRevUp ;
    separator -style "in" -h 3 sep1 ;
    floatFieldGrp -nf 3 -label "World Up Dir:" -v1 1.0 -v2 0.0 -v3 0.0 -cw4 80 50 50 50 ffgUpDir ;
    button -l "X" -w 20 -c ("floatFieldGrp -e -v1 1.0 -v2 0.0 -v3 0.0 ffgUpDir; ") -ann ("Auto Set UpDir to X-Axis") btnX ;
    button -l "Y" -w 20 -c ("floatFieldGrp -e -v1 0.0 -v2 1.0 -v3 0.0 ffgUpDir; ") -ann ("Auto Set UpDir to Y-Axis") btnY ;
    button -l "Z" -w 20 -c ("floatFieldGrp -e -v1 0.0 -v2 0.0 -v3 1.0 ffgUpDir; ") -ann ("Auto Set UpDir to Z-Axis") btnZ ;
    checkBox -l "Auto-Guess Up Direction" -v 0 cbAutoDir ;
    button -l "Orient Joints" -al "center" -c ("cJO_orientUI();") -ann ("Orient selected joints based on settings above.") btnOJ;
    separator -style "double" -h 7 sepBig ;
    floatFieldGrp -nf 3 -label "Tweak:" -v1 0.0 -v2 0.0 -v3 0.0 -cw4 80 50 50 50 ffgTweak ;
    button -l "ZERO" -w 40 -c ("floatFieldGrp -e -v1 0.0 -v2 0.0 -v3 0.0 ffgTweak; ") -ann ("Zero's tweak values.") btnZero ;
    popupMenu -p ffgTweak ;
        menuItem -l "X=1" -c ("floatFieldGrp -e -v1 1.0 ffgTweak ; ") ;
        menuItem -l "Y=1" -c ("floatFieldGrp -e -v2 1.0 ffgTweak ; ") ;
        menuItem -l "Z=1" -c ("floatFieldGrp -e -v3 1.0 ffgTweak ; ") ;
        menuItem -divider true ;
        menuItem -l "X=5" -c ("floatFieldGrp -e -v1 5.0 ffgTweak ; ") ;
        menuItem -l "Y=5" -c ("floatFieldGrp -e -v2 5.0 ffgTweak ; ") ;
        menuItem -l "Z=5" -c ("floatFieldGrp -e -v3 5.0 ffgTweak ; ") ;
        menuItem -l "X=10" -c ("floatFieldGrp -e -v1 10.0 ffgTweak ; ") ;
        menuItem -l "Y=10" -c ("floatFieldGrp -e -v2 10.0 ffgTweak ; ") ;
        menuItem -l "Z=10" -c ("floatFieldGrp -e -v3 10.0 ffgTweak ; ") ;
    button -l "Manual + Rot Tweak" -al "center" -c ("cJO_tweakUI(1.0);") -ann ("Manually rotates selected joints axis positive.") btnTweakP ;
    button -l "Manual - Rot Tweak" -al "center" -c ("cJO_tweakUI(-1.0);") -ann ("Manually rotates selected joints axis negative.") btnTweakN ;
    separator -style "in" -h 3 sep2 ;
    iconTextButton -style "textOnly" -l ("comet@comet-cartoons.com") -ann ("cometJointOrient - "+$cJO_version+" - "+$cJO_date+"  Copyright ©2004 Michael B. Comet All Rights Reserved") -c ("showHelp -a \"http://www.comet-cartoons.com/toons/\"") -h 24 email ;
    formLayout -e
        -af sep0 "left" 0
        -af sep0 "right" 0
        -af sep0 "top" 0
        -an sep0 "bottom"
        -af btnShow "left" 0
        -ap btnShow "right" 0 50
        -ac btnShow "top" 0 sep0
        -an btnShow "bottom"
        -ap btnHide "left" 0 50
        -af btnHide "right" 0
        -ac btnHide "top" 0 sep0
        -an btnHide "bottom"
        -af rbgAim "left" 0
        -an rbgAim "right"
        -ac rbgAim "top" 0 btnShow
        -an rbgAim "bottom"
        -ac cbRevAim "left" 0 rbgAim
        -af cbRevAim "right" 0
        -ac cbRevAim "top" 0 btnShow
        -an cbRevAim "bottom"
        -af rbgUp "left" 0
        -an rbgUp "right"
        -ac rbgUp "top" 0 rbgAim
        -an rbgUp "bottom"
        -ac cbRevUp "left" 0 rbgUp
        -af cbRevUp "right" 0
        -ac cbRevUp "top" 0 rbgAim
        -an cbRevUp "bottom"
        -af sep1 "left" 0
        -af sep1 "right" 0
        -ac sep1 "top" 0 rbgUp
        -an sep1 "bottom"
        -af ffgUpDir "left" 0
        -an ffgUpDir "right"
        -ac ffgUpDir "top" 0 sep1
        -an ffgUpDir "bottom"
        -ac btnX "left" 2 ffgUpDir
        -an btnX "right"
        -ac btnX "top" 0 sep1
        -an btnX "bottom"
        -ac btnY "left" 2 btnX
        -an btnY "right"
        -ac btnY "top" 0 sep1
        -an btnY "bottom"
        -ac btnZ "left" 2 btnY
        -an btnZ "right"
        -ac btnZ "top" 0 sep1
        -an btnZ "bottom"
        -af cbAutoDir "left" 20
        -af cbAutoDir "right" 0
        -ac cbAutoDir "top" 0 ffgUpDir
        -an cbAutoDir "bottom"
        -af btnOJ "left" 5
        -af btnOJ "right" 5
        -ac btnOJ "top" 5 cbAutoDir
        -an btnOJ "bottom"
        -af sepBig "left" 0
        -af sepBig "right" 0
        -ac sepBig "top" 5 btnOJ
        -an sepBig "bottom"
        -af ffgTweak "left" 0
        -an ffgTweak "right"
        -ac ffgTweak "top" 5 sepBig
        -an ffgTweak "bottom"
        -ac btnZero "left" 2 ffgTweak
        -an btnZero "right"
        -ac btnZero "top" 5 sepBig
        -an btnZero "bottom"
        -af btnTweakP "left" 5
        -ap btnTweakP "right" 0 49
        -ac btnTweakP "top" 5 ffgTweak
        -an btnTweakP "bottom"
        -ap btnTweakN "left" 0 51
        -af btnTweakN "right" 5
        -ac btnTweakN "top" 5 ffgTweak
        -an btnTweakN "bottom"
        -af sep2 "left" 5
        -af sep2 "right" 5
        -ac sep2 "top" 5 btnTweakP
        -an sep2 "bottom"
        -af email "left" 0
        -af email "right" 0
        -ac email "top" 0 sep2
        -an email "bottom"
        mainForm ;
    showWindow cometJointOrientWin;
    else    // else just pop it up from being minimized again
 * cJO_orientUI() - UI wrapper for starting an orient
global proc cJO_orientUI()
    print ("// cometJointOrient\n");
    int $nAimAxis = `radioButtonGrp -q -sl rbgAim` ;
    int $nUpAxis = `radioButtonGrp -q -sl rbgUp` ;
    float $aimAxis[] = {0,0,0} ;
    float $upAxis[] = {0,0,0} ;
    float $revAim = 1.0 ;
    if (`checkBox -q -v cbRevAim`)
        $revAim = -1.0 ;
    float $revUp = 1.0 ;
    if (`checkBox -q -v cbRevUp`)
        $revUp = -1.0 ;
    if ($nAimAxis == $nUpAxis)
       warning -sl 0 ("The AIM and UP axis are the same! Orientaiton probably won't work!") ;
    $aimAxis[ ($nAimAxis-1) ] = $revAim ;
    $upAxis[ ($nUpAxis-1) ] = $revUp ;
    float $upDir[3] ;
    $upDir[0] = `floatFieldGrp -q -v1 ffgUpDir` ;
    $upDir[1] = `floatFieldGrp -q -v2 ffgUpDir` ;
    $upDir[2] = `floatFieldGrp -q -v3 ffgUpDir` ;
    int $doAuto = `checkBox -q -v cbAutoDir` ;
    string $joints[] = `ls -type "joint" -sl` ;
    // Now do it!
    cJO_orient($joints, $aimAxis, $upAxis, $upDir, $doAuto) ;
    // End with same stuff selected!
    select -r $joints ;
 * cJO_orient() - The real worker orient proc.
 *    $joints is array of joints to orient
 *    $aimAxis = is xyz array of what axis of joint does aim
 *    $upAxis = is xyz array of what axis of joint does up
 *    $upDir = what vector to use for up direction?
 *    $doAuto = If possible will try to guess the up axis otherwise
 *        it will use prev joint up axis or else world upDir.
global proc cJO_orient(string $joints[], float $aimAxis[], float $upAxis[],
        float $upDir[], int $doAuto)
    int $nJnt = size($joints) ;
    int $i;
    vector $prevUp = <<0,0,0>>;
        // Now orient each joint
    for ($i=0; $i < $nJnt; ++$i)
    // First we need to unparent everything and then store that,
    string $childs[] = `listRelatives -children -type "transform" -type "joint" $joints[$i]` ;
    if (size($childs) > 0)
        $childs = `parent -w $childs` ;        // unparent and get NEW names in case they changed...
    // Find parent for later in case we need it.
    string $parents[] = `listRelatives -parent $joints[$i]` ;
    string $parent = $parents[0] ;
    // Now if we have a child joint...aim to that.
    string $aimTgt="" ;
    string $child ;
    for ($child in $childs)
        if (nodeType($child) == "joint")
            $aimTgt = $child ;
            break ;
//    print ("// DEBUG: JNT="+$joints[$i]+" Parent="+$parent+" AimTgt="+$aimTgt+" //\n") ;
    if ($aimTgt != "")
        float $upVec[3] = {0,0,0} ;
        // First off...if $doAuto is on, we need to guess the cross axis dir.
        if ($doAuto)
            // Now since the first joint we want to match the second orientation
            // we kind of hack the things passed in if it is the first joint
            // ie: If the joint doesn't have a parent...OR if the parent it has
            // has the "same" position as itself...then we use the "next" joints
            // as the up cross calculations
        float $posJ[3] = `xform -q -ws -rp $joints[$i]` ;
        float $posP[3] = $posJ ;
        if ($parent != "")
            $posP = `xform -q -ws -rp $parent` ;
        float $tol = 0.0001 ;    // How close to we consider "same"?
            if ($parent == "" || (abs($posJ[0] - $posP[0]) <= $tol && abs($posJ[1] - $posP[1]) <= $tol && abs($posJ[2] - $posP[2]) <= $tol ))
                string $aimChilds[] = `listRelatives -children $aimTgt` ;
            string $aimChild = "" ;
            string $child ;
            for ($child in $aimChilds)
                $aimChild = $child ;
                break ;
                $upVec = cJO_getCrossDir($joints[$i], $aimTgt, $aimChild) ;
        else
                $upVec = cJO_getCrossDir($parent, $joints[$i], $aimTgt) ;
        if (!$doAuto || ($upVec[0] == 0.0 && $upVec[1] == 0.0 && $upVec[2] == 0.0))
        $upVec = $upDir ;    // or else use user set up Dir. if needed
        string $aCons[] = `aimConstraint
            -aim $aimAxis[0] $aimAxis[1] $aimAxis[2]
            -upVector $upAxis[0] $upAxis[1] $upAxis[2]
            -worldUpVector $upVec[0] $upVec[1] $upVec[2]
            -worldUpType "vector"
            -weight 1.0
            $aimTgt
            $joints[$i]` ;
        delete $aCons ;
        // Now compare the up we used to the prev one.
        vector $curUp = << $upVec[0], $upVec[1], $upVec[2] >> ;
        $curUp = unit($curUp) ;
        float $dot = $curUp * $prevUp ;     // dot product for angle betwen...
        $prevUp = << $upVec[0], $upVec[1], $upVec[2] >> ; // store for later
        if ($i > 0 && $dot <= 0.0)
            // Adjust the rotation axis 180 if it looks like we've flopped the wrong way!
        xform -r -os -ra ($aimAxis[0]*180.0) ($aimAxis[1]*180.0) ($aimAxis[2]*180.0) $joints[$i] ;
            $prevUp *= -1.0 ;
        // And now finish clearing out joint axis...
        joint -e -zso $joints[$i] ;
        makeIdentity -apply true $joints[$i] ;
    else if ($parent != "")
        // Otherwise if there is no target, just dup orienation of parent...
        string $oCons[] = `orientConstraint
            -weight 1.0
            $parent
            $joints[$i]` ;
        delete $oCons ;
    // Now that we're done... reparent
        parent $childs $joints[$i] ;
 * cJO_getCrossDir() - Given three nodes, this gets the cross product of
 *    the directions from B->A and B->C.
global proc float[] cJO_getCrossDir(string $objA, string $objB, string $objC)
    float $cross[3] = {0,0,0} ;
    if ($objA == "" || $objB == "" || $objC == "" ||
        objExists($objA) != true || objExists($objB) != true || objExists($objC) != true)
        return $cross ;
    float $posA[3] = `xform -q -ws -rp $objA` ;
    float $posB[3] = `xform -q -ws -rp $objB` ;
    float $posC[3] = `xform -q -ws -rp $objC` ;
    vector $v1 = << $posA[0]-$posB[0], $posA[1]-$posB[1], $posA[2]-$posB[2] >> ;
    vector $v2 = << $posC[0]-$posB[0], $posC[1]-$posB[1], $posC[2]-$posB[2] >> ;
    vector $vC = $v1 ^ $v2 ;    // Do cross product!
    $vC = unit($vC) ;        // normalize
    $cross[0] = $vC.x ;
    $cross[1] = $vC.y ;
    $cross[2] = $vC.z ;
    return $cross ;
 * cJO_tweakUI() - UI wrapper for starting a joint tweak
global proc cJO_tweakUI(float $mult)
    float $rot[3] ;
    $rot[0] = `floatFieldGrp -q -v1 ffgTweak` * $mult ;
    $rot[1] = `floatFieldGrp -q -v2 ffgTweak` * $mult ;
    $rot[2] = `floatFieldGrp -q -v3 ffgTweak` * $mult ;
    // Now do it!
    cJO_tweak($joints, $rot) ;
    select -r $joints ;
 * cJO_tweak() - Tweaks the rotation of a joint the amount specified
 *    $rot = is xyz array of how much to rotate
global proc cJO_tweak(string $joints[], float $rot[])
    int $i;
        // Now tweak each joint
    xform -r -os -ra $rot[0] $rot[1] $rot[2] $joints[$i] ;
Never mind, i'm a complete moron when it comes to scripting. This works fine. ignore.
alanlashbrook
If you could post how you solved this, it would be helpful. I am having installation problems as well.
