Error loading Qt plugins for Maya 2016 after compiling
I successfully compile the modified Qt4.8.6 downloaded from autdesk lgpl webpage.
I use win7 x64,  VS2012 update4 with Win8 SDK installed, Visual studio tool/vs2012 native x64 command line, and becuase I couldn't find OpenSSL 1.0.1g build of OpenSSL, so I omited it and use this line to configure:
configure -release -stl -no-qt3support -directwrite -plugin-sql-sqlite
When I pick the qmake.exe in Qt-Creator, it doesn't not issue any error.
Yet when I compile my Qt plugin project, it produced lots of error like these:
../src/corelib/kernel/qmetatype.h(357) : error C2065: “ULONG”:  undeclared identifier
../src/corelib/kernel/qmetatype.h(357) : error C2923: “QMetaTypeId2”: 'type' : 'identifier' is invalid as template argument 'ULONG', type expected
../src/corelib/kernel/qmetatype.h(357) : error C2913: explicit specialization; 'qmetatype' is not a specialization of a class template
I searched through internet, and found a solution, I included <windows.h> which is the the header file from: C:\Program Files (x86)\Windows Kits\8.0\Include\um\Windows.h
and the compile succeed.
The problem is ,when I load my Qt plugin in Maya 2016, it loaded successfully, but for somehow when I open a scene that using Qt's graphic framework, maya always crashed. I chekc out the MayaCrashLog, here is the content:
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x00000000
Fault address:  523923B4 in D:\Program Files\Autodesk\Maya2016\bin\QtCore4.dll
0001:001513B4 Logical offset (see .map file for location)
Call stack:
(0) section:offset       Address        Frame
     0001:001513B4   0x523923B4 0x010D4170
	Module:  D:\Program Files\Autodesk\Maya2016\bin\QtCore4.dll (-exported-)
	Decl: public: bool QObject::inherits(char const * ptr64)
(1) section:offset       Address        Frame
     0001:000AC346   0xEAACD346 0x010D4690
	Module:  D:\Program Files\Autodesk\Maya2016\bin\ExtensionLayer.dll (-exported-)
	Location: QmayaSymbolCheckBox::`default constructor closure' + 0x4106 bytes
	Decl: public: void QmayaSymbolCheckBox::`default constructor closure'(void)
(2) section:offset       Address        Frame
     0001:00310350   0x51A21350 0x010D4D30
	Module:  D:\Program Files\Autodesk\Maya2016\bin\QtGui4.dll (-exported-)
	Location: QCommonStyle::drawComplexControl + 0xE90 bytes
	Decl: public: virtual void QCommonStyle::drawComplexControl(enum QStyle::ComplexControl,class QStyleOptionComplex const * ptr64,class QPainter * ptr64,class QWidget const * ptr64)
(3) section:offset       Address        Frame
     0001:003AFC59   0x51AC0C59 0x010D5010
	Location: QWindowsStyle::drawComplexControl + 0x79 bytes
	Decl: public: virtual void QWindowsStyle::drawComplexControl(enum QStyle::ComplexControl,class QStyleOptionComplex const * ptr64,class QPainter * ptr64,class QWidget const * ptr64)
(4) section:offset       Address        Frame
     0001:00377CE2   0x51A88CE2 0x010D6900
	Location: QPlastiqueStyle::drawComplexControl + 0x1A2 bytes
	Decl: public: virtual void QPlastiqueStyle::drawComplexControl(enum QStyle::ComplexControl,class QStyleOptionComplex const * ptr64,class QPainter * ptr64,class QWidget const * ptr64)
(5) section:offset       Address        Frame
     0001:000A8FF0   0xEAAC9FF0 0x010D6B70
	Location: QmayaSymbolCheckBox::`default constructor closure' + 0xDB0 bytes
(6) section:offset       Address        Frame
     0001:0033CA2B   0x51A4DA2B 0x010D73A0
	Location: QStyleSheetStyle::drawComplexControl + 0x1EDB bytes
	Decl: public: virtual void QStyleSheetStyle::drawComplexControl(enum QStyle::ComplexControl,class QStyleOptionComplex const * ptr64,class QPainter * ptr64,class QWidget const * ptr64)
(7) section:offset       Address        Frame
     0001:00484695   0x51B95695 0x010D7480
	Decl: protected: virtual void QToolButton::paintEvent(class QPaintEvent * ptr64)
(8) section:offset       Address        Frame
     0001:00070DD7   0x51781DD7 0x010D7600
	Decl: protected: virtual bool QWidget::event(class QEvent * ptr64)
(9) section:offset       Address        Frame
     0001:0002A0FD   0x5173B0FD 0x010D7630
	Location: QApplicationPrivate::notify_helper + 0x10D bytes
	Decl: public: bool QApplicationPrivate::notify_helper(class QObject * ptr64,class QEvent * ptr64)
(10) section:offset       Address        Frame
     0001:00029D90   0x5173AD90 0x010D78C0
	Decl: public: virtual bool QApplication::notify(class QObject * ptr64,class QEvent * ptr64)
(11) section:offset       Address        Frame
     0001:0000FBBF   0xEAA30BBF 0x010D7950
	Decl: public: enum TcommandLanguageContext TscriptAction::languageContext(void)
(12) section:offset       Address        Frame
     0001:0013B85D   0x5237C85D 0x010D79B0
	Location: QCoreApplication::notifyInternal + 0x6D bytes
	Decl: private: bool QCoreApplication::notifyInternal(class QObject * ptr64,class QEvent * ptr64)
(13) section:offset       Address        Frame
     0001:00070354   0x51781354 0x010D7B40
	Decl: public: void QWidgetPrivate::drawWidget(class QPaintDevice * ptr64,class QRegion const & ptr64,class QPoint const & ptr64,int,class QPainter * ptr64,class QWidgetBackingStore * ptr64)
(14) section:offset       Address        Frame
     0001:000790E2   0x5178A0E2 0x010D7C10
	Decl: public: void QWidgetPrivate::render(class QPaintDevice * ptr64,class QPoint const & ptr64,class QRegion const & ptr64,class QFlags<enum QWidget::RenderFlag>,bool)
(15) section:offset       Address        Frame
     0001:00078CDD   0x51789CDD 0x010D7D50
	Decl: public: void QWidget::render(class QPainter * ptr64,class QPoint const & ptr64,class QRegion const & ptr64,class QFlags<enum QWidget::RenderFlag>)
(16) section:offset       Address        Frame
     0001:005F8F0C   0x51D09F0C 0x010D7E10
	Decl: public: virtual void QGraphicsProxyWidget::paint(class QPainter * ptr64,class QStyleOptionGraphicsItem const * ptr64,class QWidget * ptr64)
(17) section:offset       Address        Frame
     0001:005FE7C8   0x51D0F7C8 0x010D7EA0
	Location: QGraphicsScenePrivate::_q_emitUpdated + 0x9A8 bytes
	Decl: public: void QGraphicsScenePrivate::_q_emitUpdated(void)
(18) section:offset       Address        Frame
     0001:006043F9   0x51D153F9 0x010D82E0
	Location: QGraphicsScenePrivate::drawItemHelper + 0xB9 bytes
	Decl: public: void QGraphicsScenePrivate::drawItemHelper(class QGraphicsItem * ptr64,class QPainter * ptr64,class QStyleOptionGraphicsItem const * ptr64,class QWidget * ptr64,bool)
(19) section:offset       Address        Frame
     0001:00603EE5   0x51D14EE5 0x010D8480
	Decl: public: void QGraphicsScenePrivate::draw(class QGraphicsItem * ptr64,class QPainter * ptr64,class QTransform const * ptr64 const,class QTransform const * ptr64 const,class QRegion * ptr64,class QWidget * ptr64,double,class QTransform const * ptr64 const,bool,bool)
(20) section:offset       Address        Frame
     0001:0060636D   0x51D1736D 0x010D8770
	Location: QGraphicsScenePrivate::drawSubtreeRecursive + 0x76D bytes
	Decl: public: void QGraphicsScenePrivate::drawSubtreeRecursive(class QGraphicsItem * ptr64,class QPainter * ptr64,class QTransform const * ptr64 const,class QRegion * ptr64,class QWidget * ptr64,double,class QTransform const * ptr64 const)
(21) section:offset       Address        Frame
     0001:0060412F   0x51D1512F 0x010D8910
(22) section:offset       Address        Frame
     0001:0060636D   0x51D1736D 0x010D8C00
(23) section:offset       Address        Frame
     0001:00605BA3   0x51D16BA3 0x010D8D40
	Location: QGraphicsScenePrivate::drawItems + 0x193 bytes
	Decl: public: void QGraphicsScenePrivate::drawItems(class QPainter * ptr64,class QTransform const * ptr64 const,class QRegion * ptr64,class QWidget * ptr64)
(24) section:offset       Address        Frame
     0001:00628163   0x51D39163 0x010D8FE0
	Decl: protected: virtual void QGraphicsView::paintEvent(class QPaintEvent * ptr64)
(25) section:offset       Address        Frame
     0001:0011F8C6   0xD49108C6 0x010D9080
	Module:  D:\My Documents\maya\2016\scripts\MG-PickerStudio\MGPicker_Program\Plug-ins\MGPicker_2016x64.mll (PDB)
	Decl: MGP_GraphicsView::paintEvent
(26) section:offset       Address        Frame
     0001:00070DD7   0x51781DD7 0x010D9200
(27) section:offset       Address        Frame
     0001:0040E327   0x51B1F327 0x010D9230
	Decl: protected: virtual bool QFrame::event(class QEvent * ptr64)
(28) section:offset       Address        Frame
     0001:0062CA28   0x51D3DA28 0x010D92C0
	Decl: protected: virtual bool QGraphicsView::viewportEvent(class QEvent * ptr64)
(29) section:offset       Address        Frame
     0001:0013D743   0x5237E743 0x010D92F0
	Location: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0x83 bytes
	Decl: public: bool QCoreApplicationPrivate::sendThroughObjectEventFilters(class QObject * ptr64,class QEvent * ptr64)
(30) section:offset       Address        Frame
     0001:0002A0E9   0x5173B0E9 0x010D9320
	Location: QApplicationPrivate::notify_helper + 0xF9 bytes
(31) section:offset       Address        Frame
     0001:00029D90   0x5173AD90 0x010D95B0
(32) section:offset       Address        Frame
     0001:0000FBBF   0xEAA30BBF 0x010D9640
(33) section:offset       Address        Frame
     0001:0013B85D   0x5237C85D 0x010D96A0
(34) section:offset       Address        Frame
     0001:00070354   0x51781354 0x010D9830
(35) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010D9950
	Location: QWidgetPrivate::paintSiblingsRecursive + 0x3C7 bytes
	Decl: public: void QWidgetPrivate::paintSiblingsRecursive(class QPaintDevice * ptr64,class QList<class QObject * ptr64> const & ptr64,int,class QRegion const & ptr64,class QPoint const & ptr64,int,class QPainter * ptr64,class QWidgetBackingStore * ptr64)
(36) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010D9AE0
(37) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010D9C00
(38) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010D9D90
(39) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010D9EB0
(40) section:offset       Address        Frame
     0001:00075F26   0x51786F26 0x010D9FD0
	Location: QWidgetPrivate::paintSiblingsRecursive + 0x2B6 bytes
(41) section:offset       Address        Frame
     0001:00075F26   0x51786F26 0x010DA0F0
(42) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010DA280
(43) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010DA3A0
(44) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010DA530
(45) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010DA650
(46) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010DA7E0
(47) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010DA900
(48) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010DAA90
(49) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010DABB0
(50) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010DAD40
(51) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010DAE60
(52) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010DAFF0
(53) section:offset       Address        Frame
     0001:00076037   0x51787037 0x010DB110
(54) section:offset       Address        Frame
     0001:000704DC   0x517814DC 0x010DB2A0
(55) section:offset       Address        Frame
     0001:0023AAB9   0x5194BAB9 0x010DB500
	Decl: public: void QWidgetBackingStore::sync(void)
(56) section:offset       Address        Frame
     0001:00071155   0x51782155 0x010DB680
(57) section:offset       Address        Frame
     0001:0002A0FD   0x5173B0FD 0x010DB6B0
(58) section:offset       Address        Frame
     0001:00029D90   0x5173AD90 0x010DB940
(59) section:offset       Address        Frame
     0001:0000FBBF   0xEAA30BBF 0x010DB9D0
(60) section:offset       Address        Frame
     0001:0013B85D   0x5237C85D 0x010DBA30
(61) section:offset       Address        Frame
     0001:0013D44F   0x5237E44F 0x010DBAC0
	Location: QCoreApplicationPrivate::sendPostedEvents + 0x26F bytes
	Decl: public: static void QCoreApplicationPrivate::sendPostedEvents(class QObject * ptr64,int,class QThreadData * ptr64)
(62) section:offset       Address        Frame
     0001:005FDFD4   0x51D0EFD4 0x010DBB80
	Location: QGraphicsScenePrivate::_q_emitUpdated + 0x1B4 bytes
(63) section:offset       Address        Frame
     0001:005FA94A   0x51D0B94A 0x010DBC00
	Location: QGraphicsScene::qt_static_metacall + 0x19A bytes
	Decl: private: static void QGraphicsScene::qt_static_metacall(class QObject * ptr64,enum QMetaObject::Call,int,void * ptr64 * ptr64)
(64) section:offset       Address        Frame
     0001:001508CC   0x523918CC 0x010DBDF0
	Decl: public: virtual bool QObject::event(class QEvent * ptr64)
(65) section:offset       Address        Frame
     0001:006077CE   0x51D187CE 0x010DBF70
	Decl: protected: virtual bool QGraphicsScene::event(class QEvent * ptr64)
(66) section:offset       Address        Frame
     0001:0002A0FD   0x5173B0FD 0x010DBFA0
(67) section:offset       Address        Frame
     0001:00029D90   0x5173AD90 0x010DC230
(68) section:offset       Address        Frame
     0001:0000FBBF   0xEAA30BBF 0x010DC2C0
(69) section:offset       Address        Frame
     0001:0013B85D   0x5237C85D 0x010DC320
(70) section:offset       Address        Frame
     0001:0013D44F   0x5237E44F 0x010DC3B0
(71) section:offset       Address        Frame
     0001:0016A13F   0x523AB13F 0x010DC460
	Location: QEventDispatcherWin32::processEvents + 0xBBF bytes
	Decl: public: virtual bool QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
(72) section:offset       Address        Frame
     0001:00018BD1   0x77469BD1 0x010DC520
	Module:  C:\Windows\system32\USER32.dll (-exported-)
	Decl: TranslateMessageEx
(73) section:offset       Address        Frame
     0001:000188DA   0x774698DA 0x010DC5A0
(74) section:offset       Address        Frame
     0001:00169928   0x523AA928 0x010DF8E0
	Location: QEventDispatcherWin32::processEvents + 0x3A8 bytes
(75) section:offset       Address        Frame
     0001:0009B685   0x517AC685 0x010DF910
	Decl: public: void QApplicationPrivate::openPopup(class QWidget * ptr64)
(76) section:offset       Address        Frame
     0001:00137B1C   0x52378B1C 0x010DF980
	Decl: public: int QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>)
(77) section:offset       Address        Frame
     0001:0013AB30   0x5237BB30 0x010DF9D0
	Decl: public: static int QCoreApplication::exec(void)
(78) section:offset       Address        Frame
     0001:0000D1BA   0xEAA2E1BA 0x010DFAD0
	Decl: public: void Tapplication::start(void)
(79) section:offset       Address        Frame
     0001:0000241E   0x3F41341E 0x010DFE10
	Module:  D:\Program Files\Autodesk\Maya2016\bin\maya.exe (-exported-)
(80) section:offset       Address        Frame
     0001:00024EF8   0x3F435EF8 0x010DFE90
	Location: TiteratorWrapperBidir<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator= + 0x14878 bytes
	Decl: public: class TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> > & ptr64 TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator=(class TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> > const & ptr64)
(81) section:offset       Address        Frame
     0001:00021F90   0x3F432F90 0x010DFED0
	Location: TiteratorWrapperBidir<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator= + 0x11910 bytes
(82) section:offset       Address        Frame
     0001:000149CD   0x773459CD 0x010DFF00
	Module:  C:\Windows\system32\kernel32.dll (-exported-)
	Decl: BaseThreadInitThunk
(83) section:offset       Address        Frame
     0001:0002A891   0x7757B891 0x010DFF50
	Module:  C:\Windows\SYSTEM32\ntdll.dll (-exported-)
	Decl: RtlUserThreadStart
End of stack
//crash log file name = C:\Users\ADMINI~1\AppData\Local\Temp\MayaCrashLog150530.0949.log
//version     = 16.0.1312.0
//cut            = Thu 02/26/2015, 201502261642
//current scene = unDisclosed
//command history (most recent last):
//last tool: renderWindowSelectContextItem
//panel with focus: modelPanel4
//visible panels:
// modelPanel4
//Memory usage:
// 4326.875 Mb	Free Memory
// 4822.137 Mb	Free Swap
//  722.863 Mb	Current
Looks like the QtCore I use to compile my plugin is different with the QtCore dll maya use, right?
Can anyone helps with the issue? I compile the same qt plugin for maya2011~2015 even using vs2008 and it all works well.
I really hope someone could help me out this. Thanks so much.
It all works from maya2011~2015, but just not works at 2016.
Did I compile the qt library wrong?
why do you build Qt libs yourself? You should use ones which are supplied with Maya.
Thanks for the reply again Vlad,
Did you mean writing qmake code in pro file like:
LIBS = maya's own qt dll + openMaya*
INCLUDEPATH = maya's own headers and qt headers of maya?
I just can't figure out a way to make it works when I use QtCreator as IDE.
Ha! I fixed this. It made me so struggled!!
It turns out not the issue of my Qt lib for Maya 2016, it looks like a maya / qt bug?
I used QGraphicsProxyWidget from Qt graphic frameworks in Maya 2016, then I set a QToolButton as its widget.
So under Maya2016's default QStyle, this will crash constantly when it calles drawComplexControl() method from the Style class it uses.
If I switch Maya's UI to other QStyle, this works fine, but with maya 2016's default style, this will crash.
I think this is kinda a bug of Maya. Just post here to help others who be so unlucky as to meat the situation as I did 🙂
asztalosdani
Thanks!
But how do you change Maya's UI to other QStyle?
