# error: line 1: runtimeerror: file <string> line 2: maya command error while rendering
ssiddhisanklecha
Observer Observer
ssiddhisanklecha
Observer
Observer
This "# error: line 1: runtimeerror: file <string> line 2: maya command error" appears before rendering. What to do?
Kahylan
Hi!
This error tends to appear when maya can't locate where it is supposed to render to or it has invalid characters in the name it is supposed to give the file. Go to your rendersettings and set the filepath for your render. Give it a unique name and make sure the name uses the english alphabet only and doesn't contain any of the following symbols: (){}[]/&%#\|'`^=$£".,$
I hope this helps!
bsanchez3d
I recently switched to Maya 2023 and am now getting this error when trying to render in the render view.  My project settings are set to default and I have not changed the file paths or project paths.  Here is the error in full...
# Exporting Arnold Scene...
# Converting 9 textures to .TX....
# Error: line 1: RuntimeError: file <string> line 2: Maya command error
The name of the file is set to (not set, using scene name) and I had initially set it to render to .png.  However, it would spit this error, so I restarted the scene, made sure the render settings were at default (which sets it back to a .exr output) then tried to render again.  This time it crashed and spit this crash report:
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0xE981B040
Fault address:  E7BC078D in C:\Program Files\Autodesk\Maya2023\bin\RenderUISlice.dll
0001:0006F78D Logical offset (see .map file for location)
Call stack:
Module:  C:\Program Files\Autodesk\Maya2023\bin\RenderUISlice.dll (-exported-)
Location: RenderUISlice.dllTrenderWindowSelectCtx::setRenderWindowEditor + 5C8B bytes
Decl: public: static void __cdecl TrenderWindowSelectCtx::setRenderWindowEditor(class TrenderWindowEditor * __ptr64)
Module:  C:\Program Files\Autodesk\Maya2023\bin\OpenMayaRender.dll (-exported-)
Location: OpenMayaRender.dllAutodesk::Maya::OpenMaya20230000::MRenderView::updatePixels + 12E bytes
Decl: public: static class Autodesk::Maya::OpenMaya20230000::MStatus __cdecl Autodesk::Maya::OpenMaya20230000::MRenderView::updatePixels(unsigned int,unsigned int,unsigned int,unsigned int,struct RV_PIXEL * __ptr64,bool,unsigned int,struct RV_AOV const * __pt
Module:  C:\Program Files\Autodesk\Arnold\maya2023\bin\mtoa_api.dll (-exported-)
Decl: public: static void __cdecl CMaterialView::End(void)
Location: mtoa_api.dllCArnoldRenderSession::Render + 212 bytes
Decl: public: bool __cdecl CArnoldRenderSession::Render(void) __ptr64
Module:  C:\Program Files\Autodesk\Arnold\maya2023\plug-ins\mtoa.mll (-exported-)
Location: mtoa.mllCObjectSetTranslator::operator= + 90EFE bytes
Decl: public: class CObjectSetTranslator & __ptr64 __cdecl CObjectSetTranslator::operator=(class CObjectSetTranslator const & __ptr64) __ptr64
Module:  C:\Program Files\Autodesk\Maya2023\bin\OpenMaya.dll (-exported-)
Decl: public: virtual int __cdecl THcommandObject::doIt(class TargList & __ptr64) __ptr64
Module:  C:\Program Files\Autodesk\Maya2023\bin\CommandEngine.dll (-exported-)
Location: CommandEngine.dllTmetaCommand::doCommand + 5D bytes
Decl: public: virtual bool __cdecl TmetaCommand::doCommand(class TargList & __ptr64) __ptr64
Location: CommandEngine.dllTpythonInterpreter::dispatchMayaCommand + 356 bytes
Decl: public: static struct _object * __ptr64 __cdecl TpythonInterpreter::dispatchMayaCommand(class TmetaCommand & __ptr64,struct _object * __ptr64,struct _object * __ptr64)
Location: CommandEngine.dllTpythonInterpreter::genericDispatchFunction + 96 bytes
Decl: private: static struct _object * __ptr64 __cdecl TpythonInterpreter::genericDispatchFunction(struct _object * __ptr64,struct _object * __ptr64,struct _object * __ptr64)
Module:  C:\Program Files\Autodesk\Maya2023\bin\python39.dll (-exported-)
Location: python39.dll_PyArg_ParseTuple_SizeT + 1AC6 bytes
Location: python39.dll_PyEval_EvalFrameDefault + 5CF3 bytes
Location: python39.dll_PyFunction_Vectorcall + 257 bytes
Location: python39.dll_PyEval_EvalFrameDefault + 65F5 bytes
Location: python39.dll_PyEval_EvalFrameDefault + 1F6A bytes
Location: python39.dll_PyEval_EvalCodeWithName + A9 bytes
Location: CommandEngine.dllTpythonInterpreter::executeCommand + 2F0 bytes
Decl: public: virtual bool __cdecl TpythonInterpreter::executeCommand(class Tstring const & __ptr64,bool,bool,class TinterpreterResult * __ptr64) __ptr64
Module:  C:\Program Files\Autodesk\Maya2023\bin\Shared.dll (-exported-)
Decl: public: virtual int __cdecl TpointableCmd::undoIt(void) __ptr64
Location: CommandEngine.dllTjournal::operator= + 4F6 bytes
Decl: public: class Tjournal & __ptr64 __cdecl Tjournal::operator=(class Tjournal const & __ptr64) __ptr64
Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 728 bytes
Decl: void __cdecl setMelGlobalStackLevelPtr(unsigned int (__cdecl*)(void))
Location: CommandEngine.dllSophiaExecutable::evaluate + 47 bytes
Decl: public: union Value * __ptr64 __cdecl SophiaExecutable::evaluate(void * __ptr64) __ptr64
Location: CommandEngine.dllTcommandEngine::executeCommand + A6 bytes
Decl: public: int __cdecl TcommandEngine::executeCommand(class SophiaExecutable * __ptr64) __ptr64
Module:  C:\Program Files\Autodesk\Maya2023\bin\ExtensionLayer.dll (-exported-)
Location: ExtensionLayer.dllTrepeatCommandManager::getCommandString + 1C33 bytes
Decl: public: void __cdecl TrepeatCommandManager::getCommandString(short,class Tstring & __ptr64) __ptr64
Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 31 bytes
Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 1B49 bytes
Location: CommandEngine.dllsetMelGlobalStackLevelPtr + 1663 bytes
Location: CommandEngine.dllTcommandEngine::executeCommand + 3FC bytes
Decl: public: int __cdecl TcommandEngine::executeCommand(class Tstring const & __ptr64,bool,bool,class TmelCmdResult * __ptr64,unsigned int) __ptr64
Location: ExtensionLayer.dllTscriptActionMixin::execute + 1F7 bytes
Decl: protected: bool __cdecl TscriptActionMixin::execute(class Tevent const & __ptr64,class std::unique_ptr<class TinterpreterResult,struct std::default_delete<class TinterpreterResult> > * __ptr64) __ptr64
Location: ExtensionLayer.dllQmayaQtHelper::executeCommandScript + 8F bytes
Decl: public: static bool __cdecl QmayaQtHelper::executeCommandScript(char const * __ptr64,class QObject * __ptr64)
Location: ExtensionLayer.dllQmayaIconTextButton::mouseReleaseEvent + 257 bytes
Decl: protected: virtual void __cdecl QmayaIconTextButton::mouseReleaseEvent(class QMouseEvent * __ptr64) __ptr64
Module:  C:\Program Files\Autodesk\Maya2023\bin\Qt5Widgets.dll (-exported-)
Decl: protected: virtual bool __cdecl QWidget::event(class QEvent * __ptr64) __ptr64
Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 110 bytes
Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: Qt5Widgets.dllQApplication::notify + 750 bytes
Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: ExtensionLayer.dllQmayaApplication::currentSystemMouseButtons + 671 bytes
Decl: public: static class QFlags<enum Qt::MouseButton> __cdecl QmayaApplication::currentSystemMouseButtons(void)
Module:  C:\Program Files\Autodesk\Maya2023\bin\Qt5Core.dll (-exported-)
Location: Qt5Core.dllQCoreApplication::notifyInternal2 + BA bytes
Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
Location: Qt5Widgets.dllQApplicationPrivate::sendMouseEvent + 3C5 bytes
Decl: public: static bool __cdecl QApplicationPrivate::sendMouseEvent(class QWidget * __ptr64,class QMouseEvent * __ptr64,class QWidget * __ptr64,class QWidget * __ptr64,class QWidget * __ptr64 * __ptr64,class QPointer<class QWidget> & __ptr64,bool,bool)
Location: Qt5Widgets.dllQSizePolicy::QSizePolicy + 2D3A bytes
Decl: public: __cdecl QSizePolicy::QSizePolicy(void) __ptr64
Location: Qt5Widgets.dllQSizePolicy::QSizePolicy + CBE bytes
Location: Qt5Widgets.dllQApplication::notify + 18B3 bytes
Module:  C:\Program Files\Autodesk\Maya2023\bin\Qt5Gui.dll (-exported-)
Location: Qt5Gui.dllQGuiApplicationPrivate::processMouseEvent + 936 bytes
Decl: public: static void __cdecl QGuiApplicationPrivate::processMouseEvent(class QWindowSystemInterfacePrivate::MouseEvent * __ptr64)
Location: Qt5Gui.dllQWindowSystemInterface::sendWindowSystemEvents + 90 bytes
Decl: public: static bool __cdecl QWindowSystemInterface::sendWindowSystemEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + 6A bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Module:  C:\Program Files\Autodesk\Maya2023\plugins\platforms\qwindows.dll (-exported-)
Location: qwindows.dllqt_plugin_query_metadata + 1F99 bytes
Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Location: Qt5Core.dllQCoreApplication::exec + 154 bytes
Decl: public: static int __cdecl QCoreApplication::exec(void)
Location: ExtensionLayer.dllTapplication::start + E5 bytes
Decl: public: void __cdecl Tapplication::start(void) __ptr64
Module:  C:\Program Files\Autodesk\Maya2023\bin\maya.exe (-exported-)
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 1490 bytes
Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 17E47 bytes
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 16F7A bytes
Module:  C:\WINDOWS\System32\KERNEL32.DLL (-exported-)
Module:  C:\WINDOWS\SYSTEM32\ntdll.dll (-exported-)
End of stack
//crash log file name = C:\Users\germe\AppData\Local\Temp\MayaCrashLog220424.2241.log
//version     = 23.0.0.1294
//cut            =  02/16/2022, 202202161415
//current scene = unDisclosed
//command history (most recent last):
//last tool: renderWindowSelectContextItem
//panel with focus: renderView
//visible panels:
// modelPanel4 outlinerPanel1 renderView scriptEditorPanel1
//Memory usage:
// 7672.152 Mb Free Memory
// 10284.438 Mb Free Swap
// 3161.129 Mb Current
//Python stack:
  File: "<maya console>", line 2, in <module>()
  File: "C:\Program Files\Autodesk\Arnold\maya2023\scripts\mtoa\cmds\arnoldRender.py", line 13, in arnoldRender(width=960, height=540, doShadows=1, doGlowPass=1, camera='perspShape', options=' -layer defaultRenderLayer')
    cmds.arnoldRender(cam=camera, w=width, h=height)
  File: "<string>", line 2, in arnoldRender(*args=(), **keywords={'cam': 'perspShape', 'w': 960, 'h': 540})
I will include this in my crash log report as well.  Here's a screen grab of the render settings...
1st image are the scene defaults that caused the full crash...2nd image is the actual crash dialogue...3rd image is my initial settings...not that the "Filename" is set to <Camera>/SSC_02 (that's the filename) [crash recover stuff] on the default, and the original still has the <Camera>/  if it's trying to write this as the literal file name then is that what's causing the issue?  I don't know why it's appending the <Camera>/ to my filename and I'm uncertain if that is even relevant.
default render settings (set to .exr)default render settings (set to .exr)crash dialoguecrash dialoguesettings before re-opening and using defaultssettings before re-opening and using defaults
noah_vice
Observer
Observer
Try turning off "Abort On Error" under Error Handling in the Render Settings>Diagnostics Tab
Community Visitor
Community Visitor
For some reason I only get this error when I try CPU render (in that particular scene). It still renders the GPU.
skeydzh
hey, no solution yet?
